Clay's Build Thread - Page 254 - JeepForum.com
post #3796 of 5422 Old 08-06-2012, 11:02 PM Thread Starter
Skerr
Originally Posted by cjdogtoy View Post
when I was shopping for my jeep the owner of one of the ones I looked at tells me "she fires right up", reached in turned the key, I dove out of the way, and the jeep drove into his kitchen, through the garage wall. Glad your OK Scott, and happy to hear that the project is coming together for you.
Dang Dog... that's crazy! If Clay's had been in granny and she started there would have been no stopping her!
Originally Posted by BomberJeep View Post
Its coming along great Scott. Keep up the great work. Im sure Clay is itching to take her down the road.
Thanks Bomber. I think BOTH of us are itching to drive her down the road. I kind of hit a slump right now. I can't see any point in doing anymore engine work until I resolve the manifold dilemma, as Clay doesn't want headers. There's no point in going further with the engine. I worked on wiring awhile today, but I've had a headache all day and no energy. Only a little completed this whole day.
I DID manage to stop the oil leak at the front of the pan, and THAT made me happy!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3797 of 5422 Old 08-06-2012, 11:27 PM
VACJ7
VACJ7's Avatar
If you go with the newer style intake like the one you swapped in from your 7 I have an oem exhaust manifold you can have Scott.
'84 CJ-7 |
VACJ7 is offline
post #3798 of 5422 Old 08-07-2012, 08:58 AM
243
1978 FSJ Cherokee
You are a good man Paul
Dave's 78 Build
243 is offline
post #3799 of 5422 Old 08-07-2012, 04:14 PM Thread Starter
Skerr
I have no earthly idea what I did to fix my front parking lights, but now they work with the switch?? I pulled the fuse box back out, traced all the wires again. Painstaking!!! I discovered the brake light switch wire was unplugged from the back of the fuse box, and I plugged it in. I was testnig the wires with my test light when I realized the green wire was no longer hot. Now the WHITE wire was hot??? Huh!? I don't know, I don't care, I can't explain it. But I'm serious as a heart attack! Is it possible that plugging in the brake light switch circuit changed the current flow in the harness?
So I buttoned up the front of the grill, mounted the headlights/trim rings... finally... and ran the wiring to the back of the tub. I have all the wiring in place to connect the tail lights and fuel sender. Test light indicates power to the tail lights. I take that as a good sign.
I am out of the proper size heat shrink so no more work today. I have some lder stuff, but it woun't draw up tightly, and it breaks where there is a shoulder. I guess it is too old, so I tossed it.
Why do spiders like to make webs underneath Clay's Jeep? They are a menace when on the creeper.
Clay just got home... he passed his bend test for TIG on pipe. He says it's an ice cream night! RBFs??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3800 of 5422 Old 08-07-2012, 04:21 PM
Gido
1980 CJ7
Congrats to u and congrats to clay!
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #3801 of 5422 Old 08-07-2012, 05:44 PM
pman
Woohoo! Great news on all fronts!
As far as the spiders go, I have the same problem. So far I've found NO widows (brown or black) under the chassis. Makes me creepy on my creeper. Some big ole cockroaches were living in the seats, but I've squared that problem away. We tend to have boatloads of the brown widows here, which if I have to have them I prefer as they seem much more timid. I did find a HUGE black widow that made a nest in my Hi-Lift Jack that was sitting in the corner of my garage. Man she was fast. Dead as a doornail now and no eggs either.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3802 of 5422 Old 08-07-2012, 06:09 PM
lucdog
1980 CJ5
RBF's ha p-shaw, it's a GCC night!!!
Good work today. I'll explain later on the P-lights. It's FD PR time,. It's national night out against crime. What this has to do with Firefighters is beyond me. A feather in the Chiefs hat no doubt.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3803 of 5422 Old 08-07-2012, 06:44 PM Thread Starter
Skerr
I think I sent you a PM?? Can't remember!
Thanks Gido. How's your rig doing? When you coming over this way?
Thanks pman. I have no Widows either, just small, fat, brown spiders that spew their web over everything within range! Little bastages!
I have not found any Widows around the house/shop, but we have gobs of Brown Widows (we call 'em Southern Widows) at work. They are everywhere.
Done today...
Front parking lights- operational
Headlights-final mounting/operational
Tail lights- park function operational/ brake light operational
Turn signals NOT working!! WHY?
Dash lights do NOT work. They are hanging down under the dash. When I pull the switch one click and ground the light base with a jumper, shouldn't it come on?
Right rear wheel cylinder leaking fluid down the inside of the tire. BRAND NEW!! ZERO MILES!! NEVER BEEN OUT OF THE SHOP!!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3804 of 5422 Old 08-07-2012, 06:51 PM
lucdog
1980 CJ5
PR work for the Firedepartment.
Flowing 250 GPM off the hydrant , I still have 105 psi available.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #3805 of 5422 Old 08-07-2012, 07:02 PM Thread Starter
Skerr
I... Will... Keep... My... Mouth... Shut.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3806 of 5422 Old 08-07-2012, 08:43 PM
scoutboater
1974 CJ5
Bill,
Looks like a smooth bore nozzle off the master stream still mounted to the engine, am I right? (The 105 psi pump pressure is also a giveaway if your rig is similar to ours, because the fog nozzles require 125...)
Scott,
Keep up the good work, you're still making progress. I'm not much help on the intake/exhaust issue, but even with that dilemma you still get enough done to make me jealous and wishing I had the time and space to get started on mine...
Remember gents, keep calm and carry on.
scoutboater is offline
post #3807 of 5422 Old 08-07-2012, 09:00 PM
lucdog
1980 CJ5
Originally Posted by scoutboater
Bill,
Scott,
1.5" smooth bore, flowing at 50 psi. The 105 is the residual. I didn't have it in pump gear. It was straight off the hydrant, thru the pump and then the nozzle. Still mounted and piped thru the machine.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #3808 of 5422 Old 08-07-2012, 09:39 PM
VACJ7
VACJ7's Avatar
Scott, sent you a PM. Here is the manifold I have off my '84. Is this gonna work with the intake manifold you have or are you gonna need a later intake as well?
'84 CJ-7 |
VACJ7 is offline
post #3809 of 5422 Old 08-07-2012, 09:57 PM
lucdog
1980 CJ5
Done today...
The flasher is in , and in the correct spot, and it's a known good flasher? When the signal lights are turned on, are there no lights or just no flashing.
Dash lights- known good bulb? The switch not turned all the way to dome lights. The biggie-There is a resistance needed for dash lights to work. Meaning they all, or at least 1/2 half of them need grounded to work. A short story.
Put a automotive light switch in my boat, to dim the dash lights. I used a 12 volt test light to find the proper lugs on the back of the switch, there was 12 v to the supply. WTH none of them worked, or the light was so dim you couldn't see it. Added 3 or 4 lights in the test , cool dimming lights. Don't ask me why, that's the way it is. So hook up 3 dash lights and see what happens. A 12 volt Test meter should also be used. It's a resistance thing. One light won't be enough.
Wheel cylinder, there are two different ones, 2"x11, and the 10", double check you got the correct part. This is the one for 11" rears, right side.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #3810 of 5422 Old 08-07-2012, 10:05 PM
VACJ7
VACJ7's Avatar
I was wondering what this was all about. Neighborhood I drive through on the way home had a sign up about National Night Out and there was a fire truck there this evening with kids climbing on it.
'84 CJ-7 |
VACJ7 is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 11:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 10:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
