Clay's Build Thread - Page 246 - JeepForum.com
 38Likes
post #3676 of 5450 Old 07-24-2012, 04:33 PM
Turtle71
1983 CJ7
I saw this and thought it was a pretty cool idea for soldering.
http://staceydavid.com/articles/tips...ing-clamp-4075
My 83 CJ7 Build:
Turtle71 is offline
post #3677 of 5450 Old 07-24-2012, 05:19 PM
cjdogtoy
1976 CJ5
there you go duct tape the spray cap to the inside of the dash or fire wall to hold things still.
cjdogtoy is offline
post #3678 of 5450 Old 07-24-2012, 05:24 PM
Dadamsnv
1977 CJ5
genius!
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #3679 of 5450 Old 07-24-2012, 05:49 PM Thread Starter
Skerr
That's pretty cool! I'll see if I can do it under the dash, upside down! Thanks!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3680 of 5450 Old 07-24-2012, 06:00 PM
pman
Originally Posted by 243 View Post
Scott,
Getting the upper main seal out may be a bear, if you have to punch it out make sure you don't use a steel punch or you can damage the crank.
Skipper-
You DID remove the top piece of the RMS didn't you (what 243 is referring to)? I might be reading your post wrong, but it sounded like you just replaced the seal in the bottom bearing cap. The top one should be replaced while you are in there.
If you didn't, heed 243's advice and use a brass punch so you don't scratch the bearing surface.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3681 of 5450 Old 07-24-2012, 09:35 PM Thread Starter
Skerr
Originally Posted by pman View Post
Skipper-
Yeah, sorry... didn't mean to mislead anyone. We had company, and I was trying to listen and type at the same time! Clay and I replaced both pieces of the RMS. I got the top piece out in whole condition, although it was brittle. I was careful to not scratch any of the bearing surface. I am, however, worried about the open condition it is in right this moment (oil pan is still off). I could not button everything up, as I said, we had comapny! So the bottom of the engine is open. I want to clean out the burned-in gunk that I see "up in the corners" of the block. Is it reasonable to spray it all down with brake cleaner or carb cleaner? Some kind of flush to get all the gunk out?
My Chilton's says, as near as I can tell, that the torque specs for the bearing cap is between 75-85 ft/lbs. Can anyone confirm this is correct?
Thanks, All...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3682 of 5450 Old 07-24-2012, 09:41 PM
8pitcher
8pitcher's Avatar
Yes 75-85 ft lbs
8pitcher is offline
post #3683 of 5450 Old 07-24-2012, 10:08 PM
Dadamsnv
1977 CJ5
I've heard 100 ft lbs. I hate to make it confusing :/ I did mine to 100
Dadamsnv is offline
post #3684 of 5450 Old 07-24-2012, 10:11 PM
8pitcher
8pitcher's Avatar
I looked in my manual.
8pitcher is offline
post #3685 of 5450 Old 07-24-2012, 10:12 PM
8pitcher
8pitcher's Avatar
100 for 304
8pitcher is offline
post #3686 of 5450 Old 07-24-2012, 10:16 PM
Dadamsnv
1977 CJ5
Originally Posted by 8pitcher
100 for 304
Touché
Dadamsnv is offline
post #3687 of 5450 Old 07-25-2012, 06:36 AM
Jim1611
Jim1611's Avatar
Catching up with what's going on. Not likely to hurt having the pan off for a short while Scott. My biggest concern would be the wind blowing sand up in there though, you have talked about that problem in the shop before. You sure don't want any gritty material in there. Diesel fuel would make a pretty good flush for the inside of the block. They make stuff for the outside, like gunk, but that needs to be flushed with water and you can't do that for obvious reasons. Brake cleaner might attack the seals too so maybe you need to stay away from that.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3688 of 5450 Old 07-25-2012, 06:58 AM
gmakra
Skipper a picture is worth a thousand words and we only had 250 words yesterday.
So I gotts to eat me words of wisdom I gave to you yesterday. The guys is correct thats yer oil pan gasket fro a four piece now Ya ll now have a one piece.
As Jim said its not really a big deal if you have the crankcase open for a few days, I would just change the oil or as Ya ll say earl after the first run to flush any crud out.
BTW the word CRUD comes from the nuclear field they built one of the first reactor on Chalk River and when they opened it up there was an unidentified deposit in the bottom, so they called it Chalk River Unidentified Deposits.
gmakra is offline
post #3689 of 5450 Old 07-25-2012, 10:45 AM
Turtle71
1983 CJ7
I guess I didnt fully understand the predicament you are in. I guess that's what I get for reading too fast
My 83 CJ7 Build:
Turtle71 is offline
post #3690 of 5450 Old 07-25-2012, 12:29 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I just usually slip the heat shrink over the one wire, strip 1/4-1/2" of each wire, mate them end-to-end with a little overlap, then twist them around each other so that they are inline (not twisted like a twisty-tie would be around the bread bag). This gives a solid mechanical joint, then a dab of flux if it is older wire and a good heating with the soldering iron while holding the solder to the other side of the wire. I may sometimes put a dab of solder on the tip of the iron (more than you wold when tinning it) which seems to help the heat transfer to the wire.
Rick
Cutlass327 is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
