Clay's Build Thread - Page 231 - JeepForum.com
 48Likes
post #3451 of 5466 Old 07-06-2012, 07:06 PM Thread Starter
Skerr
Clay and I have been working like a couple of pigs all day. Lots of little things done on his rig. With Doctor Bill's help, we performed surgery on the dizzy. I have never touched one in my life! I have always known if you mess with the dizzy your engine may not run again, so I didn't mess with it when we pulled, cleaned, painted Clay's engine. But with Dr. Phil...er...BILL, sitting "close" I pulled the dizzy, prelubed the engine, completed the Team Rush upgrade, and reinstaled the dang thing. Piece. Of. Cake! But will it run?
Things I learned...
TDC can be on exhaust or compression stroke. BE SURE you are on the compression stroke. My distributor was 180* out at TDC. See pic 1 and 2.
Prelubing your engine is easy and cool! We changed the oil and pumped it up to 70 PSI, but held it at 50 PSI to lube everything. I modified a large screwdriver and used my 1/2" drill.
The clerk at your local parts store will try to give you parts specific to your year model, despite the fact you are giving him/her part numbers. Nice of them to think they are providing what you need, but it cost me extra trips to town.
The middle two pics are just cruddy pics. The old cap was tossed. The dizzy was cleaned up.
The last two pics are what I thought is a coil. According to the Team Rush upgrade I need this part, but I can't see how/where it fits in my application. I thought it replaced the part circled in the dizzy pic, but it doesn't. Is this part not needed, or am I missing something?
Thanks.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3452 of 5466 Old 07-06-2012, 07:34 PM Thread Starter
Skerr
Originally Posted by DutchJPR View Post
Nicely done!
Why don't you get one off those angled PCV's, then you tubing is long enough, and it looks way better.
Got it Dutch. Thanks.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3453 of 5466 Old 07-06-2012, 07:44 PM
Jim1611
Jim1611's Avatar
You better clean the dust off that ole thing Scott, it'll be easier to move around.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3454 of 5466 Old 07-06-2012, 07:54 PM Thread Starter
Skerr
Boy don'tcha know! More truth than fiction in that statement Jim.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3455 of 5466 Old 07-06-2012, 08:31 PM
VACJ7
VACJ7's Avatar
Scott, tha last pic is the connector to your coil. Slides over the brass terminals on the can-style coil. You can see one of the posts in the first pic.
'84 CJ-7 |
VACJ7 is offline
post #3456 of 5466 Old 07-06-2012, 08:36 PM Thread Starter
Skerr
Thank you Paul. I will solve that mystery tomorrow.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3457 of 5466 Old 07-06-2012, 08:40 PM
VACJ7
VACJ7's Avatar
Excellent! I on the other hand don't plan on doing squat tomorrow. 107* in the forecast!
'84 CJ-7 |
VACJ7 is offline
post #3458 of 5466 Old 07-06-2012, 08:47 PM
lucdog
lucdog's Avatar
1980 CJ5
Paul is correct, if you look at the pictures of your wire harness you can see the same part. If the old one looks ok, return the new one. Check the one on your 7.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3459 of 5466 Old 07-06-2012, 09:10 PM Thread Starter
Skerr
Bill
Ah yes... the harness has one. I will check it out tomorrow. My 7 doesn't have one. I may save it for it. Thanks Doc Bill!
edit* BOINK!! My 7 does too have one. Thanks AGAIN Doc Bill.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3460 of 5466 Old 07-07-2012, 03:46 PM Thread Starter
Skerr
MoC mailed me a dash (FREE) a couple weeks ago. And it hasn't arrived. I know it's coming, but I am getting concerned. I can't install the cage until the dash is in, and I have the wiring to do too. So, with a slight amount of panic, and no small dash of worry, I began to reclaim Clay's dash. he warped it pretty bad welding on it, and my '70s era JBL speaker fell from its perch right on top of the dash, as it sat suspended across the double sink in my shop. So it was bent. I had a lot of work to do. Heating, shrinking, bending, shaping, hammer/dolly (and I don't own a hammer and dolly!), grinding, sanding, smoothing, welding, more grinding, wire-wheeling... etc! I cleaned it with Prep All, sprayed it with trunk paint to provide texture (to hide the imperfections), ran out of trunk paint at the exactly correct moment, while sweat streamed down my face, shirt clinging to me like a contest, and the mail lady pulled into my yard. Yep. You guessed it. The dash arrived!! It is a perfect dash. Thank you MoC. You are a blessing. I will paint it up and get it ready.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3461 of 5466 Old 07-07-2012, 04:30 PM
Jim1611
Jim1611's Avatar
Clearcoat it, I like the sandblast look. MoC is the man!!
My build thread
Jim1611 is offline
post #3462 of 5466 Old 07-07-2012, 07:05 PM Thread Starter
Skerr
The white dash is the one that MoC sent. It is perfect and flat. I can't believe it showed up when I finished working on Clay's ratty dash. I guess that will teach me to be a little more patient.
I will work on MoC's dash tomorrow and maybe I can get it painted. We installed the cage (on my command!) because I think I can get the dash installed after the cage, only to find out I am WRONG, and now I have to remove the cage, which is crammed in place! How do you guys do this patience thing? I am ready to work.
UGH!
Here's pics of the cage in place. At least I got that! It doesn't sit flat, and it is torqued somehow. No idea how that happened since it was built in place.
Had a youth group over this evening. Why you reckon all the young ladies end up sitting at the kitchen table, and all the young men end up outside at the Jeep!? They helped Clay get his cage installed.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3463 of 5466 Old 07-07-2012, 07:15 PM
MoC
Looks great Scott! So glad I was able to help you and Clay out with the dash.
MoC is offline
post #3464 of 5466 Old 07-07-2012, 07:19 PM
pman
Sounds like you need to have another youth group meeting tomorrow (to remove the cage). That is odd that it isn't sitting flush. Looking great, though! That's a serious setup!
Btw, had to laugh at the first pic. You have this look of "boys, if one of ya scratch that paint........."
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3465 of 5466 Old 07-07-2012, 07:22 PM Thread Starter
Skerr
When you said it needed work I was expecting something rough. It is nearly perfect! All I have to do is scuff it and paint it. I will transfer Clay's little kicker panel over to it and paint it up. MUCH APPRECIATED MoC.
Kerrdog
Go Fish! <*////><
Skerr is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
