Clay's Build Thread - Page 225 - JeepForum.com
 48Likes
post #3361 of 5466 Old 06-29-2012, 11:09 AM Thread Starter
Skerr
Originally Posted by DutchJPR View Post
Trow the harness in, then connect the things you know. I think thats the easiest way....
Dutch... you did see where I mention I completely blank out!?!?!?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3362 of 5466 Old 06-29-2012, 11:25 AM
DutchJPR
Lol...... I'll throw in some more.....
1th pic. right to left: starter,starter relay, battery, alternator(red wire, two connectors), oil pressure sender.
2th pic right to left: oil pressure sender, ignition coil(half moon shapeped thing),? and ? then distributor.
3th pic left under: right side marker, right headlamp and flasher. left midlle: water temp sensor (angeled connector)
4th pic left to right: left side marker, left headlight and flasher, horn, windshieldwasher? ingnition module motorcraft(two rond connectors), fusebox.
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
DutchJPR is offline
post #3363 of 5466 Old 06-29-2012, 11:31 AM
Moogs
In the 2nd pic the half moon thingy I believe is for the coil.
Moogs is offline
post #3364 of 5466 Old 06-29-2012, 11:45 AM
DutchJPR
Basicaly the wiring harness has two sides.
One for the engine, it goes roughly from fusebox, ignition module, then to the carb, across the engine over the firewall, tranny's, heater fan then coil and distributor, alternator, and ends at the starter.
Second for the lightning and accesoiry, it goes on the left inner fender to windscreenwasher, horn, left lightning, across the radiator to the right lightning.
Together with the above you should be able to re-connect it.
For referece you could use this scedule. Do print it out, large sized, put it on the wall of the shed. All connectors are on it!
Left under (CDE/1234) is the 6cil enginebay wiring.
I missed the brake safety light, don't know exacly where it's located in the harness.
DutchJPR is offline
post #3365 of 5466 Old 06-29-2012, 01:06 PM Thread Starter
Skerr
I will come back to the wiring... don't want to break the momentum we have going today. Ordered parts from Morris day before yesterday. Fedex arrived a bit ago, bringing most of the order, including this brand new, unopened, still in the package headlight switch knob. What's wrong widit? Already had to call about new parts quality.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3366 of 5466 Old 06-29-2012, 02:09 PM
lucdog
lucdog's Avatar
1980 CJ5
Yea, where is the insert for the knob.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3367 of 5466 Old 06-29-2012, 02:11 PM Thread Starter
Skerr
Well, shoot! Momentum busted. Clay says he needs a rest! He is laying on the beanbag watching Dick Van Dyke Show (DVD). I have a pretty significant list for him to pick up in town. I don't HAVE to have those things today, but it is things I could be doing, like the vent nipples for the axle housings. I also need nipples for the MC2100 bases (mine needs one too) for PCV vacuum. Gotta drill and tap holes for them as well. Oh well. When they're 2 years old they want to help Dad. When they're 18, they have to have some say-so.
Things DONE today...
Re-installed the intake/exhaust manifolds. Clay's TIG job is beautiful. Wore out my rotary file and a stone making the bolt hole round again!
Installed other spring plates in the front. PO had welded bolts on for shocks. That is changed now, and I have a place for sway bar (which we have) if we choose to install it.
Wire-wheeled areas of the frame where we had done some welding, applied self-etch primer. Need to brush on some black.
CJ3B said "NO, we can't have Clay's wheel back!" Gonna be a fight!
Went back out to the shop (while Clay was resting!) and discovered one of my big JBLs fell! The bracket went on break! The whole thing came crashing down, and it ended up on my Workmate. But it bounced off Clay's dash first!!!!!!!! Can't use it for sure, now. Bent beyond recognition! Glad MoC is sending us another.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3368 of 5466 Old 06-29-2012, 02:17 PM Thread Starter
Skerr
Morris is sending out a new one today. YAY! Keeping the bad one I guess, but why?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3369 of 5466 Old 06-29-2012, 02:18 PM Thread Starter
Skerr
Dang, you are so sharp!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3370 of 5466 Old 06-29-2012, 02:28 PM
2girlsAndaGuy
1979 CJ5
that dash sure had a bad omen around it, guess it was letting you know one last time that is was a lost cause.
David
2girlsAndaGuy is offline
post #3371 of 5466 Old 06-29-2012, 02:29 PM Thread Starter
Skerr
zzzooonnniiinnnggg ooouuuttt... III ssseee llliiinnneeesss aaannnddd bbblllooobbbsss! must make it to the sun. only sun's rays can save me. must... get... outside... feeeeeling weeeaaak! unnmmmph...
Working on it Dutch. Gonna be tough. Thank you.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3372 of 5466 Old 06-29-2012, 02:31 PM Thread Starter
Skerr
No Kidding! Thinking about turning it into a grill.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3373 of 5466 Old 06-29-2012, 02:31 PM
lucdog
lucdog's Avatar
1980 CJ5
In case some one needs one, that's why. The insert is just glued on. What if the knob pulls off the shaft on your 7.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #3374 of 5466 Old 06-29-2012, 02:42 PM
2girlsAndaGuy
1979 CJ5
na, just hang it above your shop.
David
post #3375 of 5466 Old 06-29-2012, 02:44 PM
DutchJPR
Makes a nice skewer for the dash grill
DutchJPR is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
