Clay's Build Thread - Page 153 - JeepForum.com
post #2281 of 5422 Old 01-15-2012, 05:23 PM Thread Starter
Skerr
Originally Posted by SonicR1 View Post
Opened up my garage to work on the TJ today… it was a balmy 65… I love Ca!!!! Except for the lack of snow in the hills right now………..
Airsoft is fun… hehehehehe, except for cleaning up the bb's when you are inside...
Bill... you are avatarless!! SUP with that? NO Airsoft in the house here. Good way to get yourself in some deep hooey!
Here are a couple action pics from today. We had an absolute ball! WM has these inexpensive ($10) 1911 knockoffs. They work well but you gotta be close. Those little jokers sting like fire!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2282 of 5422 Old 01-16-2012, 02:21 PM Thread Starter
Skerr
Here are the LEDs and the plan I have/had. I think it has changed somewhat!? Some of you guys who have done LEDs will know the answer... I hope!
I bought the lights at WM for $15 a piece. I thought it was good price. The product looks good, and they're bright as heck. Being my first adventure with LEDs I may have done the wrong thing. That's for you guys to tell me. I can take them back if necessary.
I THOUGHT I needed a 4 1/2" diameter ID pipe for a receptacle, but a neighbor dropped by today and said I needed a 5" pipe with 1/8 wall thickness. He said the pipe has to have a lip for the rubber base to "snap" into. I can find 5" pipe if this is true. However, Clay is leaning toward oblong lights rather than the round so we can insert them entirely into the bumper. If we do that then I will save the round lights for MY tub when we finish his.
Need your input here...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2283 of 5422 Old 01-16-2012, 02:28 PM Thread Starter
Skerr
And just for fun, here is the stash of pipe we bought to use for the cage and the welding table that the owner of the metal yard gave us. The table has a rather thin top, but we can weld some 1/4" to it if it ever becomes necessary.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2284 of 5422 Old 01-16-2012, 02:57 PM
MoC
LEDs look nice!
MoC is offline
post #2285 of 5422 Old 01-16-2012, 06:41 PM
gmakra
Once again I have had my friends snoop around Skippers house and these pictures were emailed to me. As you can see Skipper and Bill are discussing LED install and heres a pic of Scotty doin a photo op
gmakra is offline
post #2286 of 5422 Old 01-16-2012, 08:21 PM Thread Starter
Skerr
Skipper... did I get it right this time?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2287 of 5422 Old 01-16-2012, 08:38 PM
lucdog
1980 CJ5
This is the reason I don't go to Chicago.
Looks like a good time was had by all. Happy Birthday Clay.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #2288 of 5422 Old 01-16-2012, 10:21 PM
Jim1611
Jim1611's Avatar
Happy birthday to Clay!!! Hey don't forget to go to the post office and register with the armed services in case they want to draft you. That was a long time ago for me but I still remember it!
Hope it's a great day for you Clay.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #2289 of 5422 Old 01-17-2012, 12:24 AM
rixcj
rixcj's Avatar
1979 CJ5
Scott...those led light grommets are meant to snap through a hole in 3/16, or 1/4 inch thick steel..whatever the distance between that "bead" or whatever you want to call it, and the part of the grommet that begins to taper out (3rd pic. down). Like,through the wall thickness of your bumper.
So...if the O.D. of the grommet, between the bead and the taper is 4.5", and the bead sticks out .125" (let's say...) you'd need to cut a 4.5" hole in your bumper. Then find a piece of pipe (tube) that had an I.D. at least large enough to fit over the bead. In our example, an I.D. of at least 4.75". This would be centered over your 4.5" hole on the bumper. Now you have a lip. You push the grommet in, and the bead will snap over the 4.5" hole.
So that DOES work out to be 5" O.D. pipe with a .125" wall.
Unfortunately, Clay's idea is probably better because your lights SHOULD fit entirely in the bumper, but they don't.
Hopefully, your bumper is the approximate thickness of the bead-to-taper distance of the grommet, for a nice fit.
Am I making sense?
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2290 of 5422 Old 01-17-2012, 11:47 PM
SonicR1
Yeah, my subscription ran out and my toy account is dry for a few weeks (spending too much money on the TJ!!!), so until it gets filled, avatarless I will be...
Personally, I like the round flush mounts, the oblong ones remind me too much of trailer lights.
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #2291 of 5422 Old 01-18-2012, 07:47 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Usually the lights are installed in the metal without a tube. We use those things all day long on trucks and trailers. The 'glass may give you an issue, depending on how thick it is if that is where you are putting them. If the plans are in the bumper, depending on how thick the metal is, it should just fit in the hole you cut out. I've seen them put into maybe 1/8" thick trailer taillight housings, you might be able to go thicker, depending on the grommet. Those ones you have there look like the ones we have at work that are always a PITA to get the light in, once you fight to get the grommet in place. I looked on Google for a pic, but couldn't find a good one. I'll try to get a pic of one at work today. The ones we use don't have the large lip on the back like that one does, so it might not be as picky on metal thickness.
Rick
Cutlass327 is offline
post #2292 of 5422 Old 01-18-2012, 08:52 AM
lucdog
1980 CJ5
This is exactly what I thought
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #2293 of 5422 Old 01-18-2012, 04:43 PM Thread Starter
Skerr
Am I making sense?
Rich
IIIIIIIIII haaaaaaad toooooooooo reeeeeaaaaad thiiiiiiiiiiiiiiiiiiissssss sloooooooooooooow. Nowwwwwwwwww IIIIIIIIIIIIII geeeeeeeet iiiiiiiiiiiittttttttt!
Tighten up Bill! And I like the round ones better too, but Clay got some ovals last night. I haven't checked yet, but it's posible they could fit in the tub??? Hmmmm...
That was my original plan... to stick them in the tub. But I boogered that up by raising up the gas filler door and taking away the space for the lights. Now I don't have an area to mount the lights unless I glass up the hole for the gas filler, and I ain't doing it! So maybe we'll go oval in the bumper. I think the ovals would look better in the tub.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2294 of 5422 Old 01-18-2012, 05:02 PM
lucdog
1980 CJ5
If you really want to be different. Guys used tail lights from 73 to 88 GM trucks, and till 91 on Blazers, Jimmys, and Suburbans. I haven't done this, my BIL did, back in the late 70's. From what he said, the radius is the same as Jeeps.
Just a thought.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #2295 of 5422 Old 01-18-2012, 06:54 PM Thread Starter
Skerr
Just a thought.
Bill
Thought about that, but I wanted the LEDs. Now we have these ugly oval lights!
And don't tell Clay I posted up this second pic. He got a DeWalt drill, some clamps, and a He-Man DVD... the struggle from a boy to a man!!!! Do I ever remember THOSE days!
Kerrdog
Go Fish! <*////><
Skerr is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 11:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 10:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
