Clay's Build Thread - Page 152 - JeepForum.com
 48Likes
post #2266 of 5466 Old 01-13-2012, 03:46 PM Thread Starter
Skerr
[QUOTE=gmakra;12848663]Ok all you electrical neophites. Electricity has three basic measurements volts, amps and resistance.Most of the other terms you hear are combinations of these three. (there is more to it, but I am trying to keep it simple)
Volts is the velocity of the electricity think of it as water pressure.
Amps is the volume of electrons think of gallons per minute.
Resistance is friction.
Power (watts)is the total comsumption of electricity. To give you an idea of what I am talking about lets use a gallon of water. What we are going to do is fill a one gallon container. Now you can use tea spoons of water or pints, quarts any any size measuring device or combination of measuring devices as long as you fill this container to one gallon.
So power (watts) is overall consumption. One horsepower of electricty is 746 watts. It does not matter what voltage nor anything else. Its like a gallon of water its a contsant and to show you this I will show you a couple of simple formulas.
Power
divide
Current(amps) multiply volts
This is how you work the formula to find a missing value. If you multiply amps X volts it will give you power. If you know the power but are missing the amps you then divide volts into power.
Take a 1400 watt blow drier and you want to know how mamy amps it draws you would divide 120 volts into 1400 watts and you will come up with 11.66666 Amps. And if you take that 1400 watt blow drier and divide it by 746 watts you will see that it comes up with 1.8766 horsepower.
Now wire size can create resitance. You would not fight a forest fire with a garden hose since you wont get enough pressure or volume to really be effective. This also holds true with an extension cord, a long thin cord will create alot of resistance cutting down on voltage and amperage making your power tool sluggish it can also make your tool run hot which leads to insulation break down. A electric motor requires 7 time the run amperage to start. So if your toll runs at 10 amps it takes 70 amps to start.
So Scotty the up shot of all this is use a thicker extension cord your saw will probably run better. Also change the blade it sounds like a cheap one thats not balanced.[/QUOTE]
25' 10 gauge industrial cord... no problems there. No problem with blades or balance. It's just slow, but I can deal with it. Ken has the vibrating saw blade.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2267 of 5466 Old 01-14-2012, 09:09 AM
Gido
1980 CJ7
Did you try a hammer? Oh wait, it's an electrical problem!
Skerr likes this.
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #2268 of 5466 Old 01-14-2012, 12:20 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
We have the exact one lucdog posted a pic of at work..
Rick
Cutlass327 is offline
post #2269 of 5466 Old 01-14-2012, 03:47 PM
lucdog
lucdog's Avatar
1980 CJ5
Gmakra, o boy I hate math.
P=IE,
P IS power in watts
I is amps
E is voltage
I=ER
Same thing, except "R" is resistance.
&pi;r2, corn bread are round.
George sounds like the Cowardly Lion, after he got his brain from the Wizard.
Later TOTO,
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #2270 of 5466 Old 01-14-2012, 05:23 PM Thread Starter
Skerr
P=IE,
P IS power in watts
I is amps
E is voltage
I=ER
Later TOTO,
Bill
NO!! You're wrong. Cornbread are SQUARE!! PIE are round. Gotta teach you everything...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2271 of 5466 Old 01-14-2012, 09:50 PM
lucdog
lucdog's Avatar
1980 CJ5
If I wouldn't have done that, you wouldn't have any thing else to do. . Just trying to keep ya on your toes.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #2272 of 5466 Old 01-14-2012, 10:13 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Originally Posted by Skerr View Post
Took some pics of our "frozen" landscape. My peach trees have fruit on them already, and I am running sprinklers to insulate the fruit and buds. It was 18*... cold enough to cause a tree to freeze and explode.
I didn't move to FL for this crap, I moved here to never see it again
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #2273 of 5466 Old 01-14-2012, 10:17 PM Thread Starter
Skerr
You and the other 999 people that move into my home everyday!! You can't fool me... you were probably running around in shorts while I was wearing my 10X coveralls!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2274 of 5466 Old 01-14-2012, 10:24 PM Thread Starter
Skerr
Power
divide
I read this again, George, to try and grasp the concepts you presented. I studied it hard... wracked my brain... fretted over it, even, but in the end I come up with the same ending. All that talk about water makes me have to pee! Ooops!! I'll be back in a minute...
The hammer is your friend! Good one, Gido.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2275 of 5466 Old 01-14-2012, 10:28 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
It's down to 28* under my carport right now and dropping, WTF??????
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #2276 of 5466 Old 01-14-2012, 10:34 PM Thread Starter
Skerr
Dude... close the fridge!! It's only 41 here.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2277 of 5466 Old 01-15-2012, 06:39 AM
lucdog
lucdog's Avatar
1980 CJ5
Rofl, bunch of wimps, I tell ya.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #2278 of 5466 Old 01-15-2012, 07:02 AM
rixcj
rixcj's Avatar
1979 CJ5
It's 14 degrees here...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2279 of 5466 Old 01-15-2012, 02:03 PM Thread Starter
Skerr
Clay turns 18 on the 18th! We're celebrating today with a surprise party. AIRSOFT WARS!!!! Capture the Flag. Pics of the carnage later...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2280 of 5466 Old 01-15-2012, 04:03 PM
SonicR1
Opened up my garage to work on the TJ today… it was a balmy 65… I love Ca!!!! Except for the lack of snow in the hills right now………..
Airsoft is fun… hehehehehe, except for cleaning up the bb's when you are inside...
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
1979 , cj5 , fiberglass , rollcage , tailgate
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Looking for a CJ Build Thread. jsc7002 Jeep CJ Forum 6 08-22-2009 10:47 AM
High 5 Build Thread... 1Rustycj5 Jeep CJ Forum 7 03-22-2009 09:28 PM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
