The classic 'left over parts' question - JeepForum.com
post #1 of 7 Old 09-07-2011, 08:11 PM Thread Starter
CJOFlorida
1981 CJ7
I just replaced the power steering gearbox on my 81 CJ-7. I got a new bell coupling that connects the steering shaft to the steering gearbox but the splines didn't exactly fit. I ended up using the old bell housing with new insides. It worked out fine but the spring clip that holds the two steel cubes inside the bell housing was giving me fits during reassembly and I ended up leaving the clip out. It doesn't seem to do anything once everything is assembled. I just want to know how big a mistake this was. The steering seems to work fine in the garage but I haven't driven it yet. Thoughts?
CJOFlorida is offline
post #2 of 7 Old 09-07-2011, 08:36 PM
BagusJeep
1981 CJ7
A lot of info there but unclear as to whcih part you have left out. Which one is it in this diagram?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 7 Old 09-07-2011, 11:10 PM
only in a jeep cj
I trick that I learned seems to work if the joint is starting to get loose. Turn each of the blocks 90 degrees and drive out the center pin and turn that 90 as well when you push it back in. This gives all the tension surfaces (during the left and right movement) new or unworn areas. Only the aluminum channel is old. Did your bell kit come with a new center pin as the pics Ive seen of them does not show it. It needs to be replaced too along with the blocks if your going that route. Yes, I remember needing the clip as it held the blocks in the correct alignment or something.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 7 Old 09-08-2011, 11:17 AM
Pathkiller
1974 CJ5
You're willing to risk your life on the assumption that that clip really wasn't important? Or the lives of everyone else on the road around you? Steering is kinda important.
Pathkiller is offline
post #5 of 7 Old 09-08-2011, 06:57 PM Thread Starter
CJOFlorida
1981 CJ7
This is the kit that the part came in. The clip I'm talking about is in the top right corner.
post #6 of 7 Old 09-08-2011, 07:26 PM
mopar346
I'm trying to remember but it seems like the clip hold the cubes out board to take up clearance. I have done many although it has been awhile and non of them were Jeeps. I don't believe there is enough room for it to come loose or mis-steer without the clip, but do you really want to risk it on IF I remember and I DON"T THINKs. I would let it sit clear my head and go back at and assemble complete with everything.
Careful your character's showing
mopar346 is offline
post #7 of 7 Old 09-08-2011, 07:27 PM
yellow85cj
It is to act as a spring to hold the square blocks out from the shaft. Goes on before you put the square blocks on, then put the blocks on, then slide the bell over.
Currently in pieces - all of them
yellow85cj is offline
Left blinker comes on with both right and left SBpunk Jeep CJ Forum 6 07-30-2011 01:07 AM
Parts Value Question? toyotajeep44 Jeep CJ Forum 2 05-22-2011 11:08 AM
parts question? HELP!!! dougchri Jeep CJ Forum 0 08-22-2010 06:01 PM
Classic tire size difference question 750-15 to 700-15 xj deluxe Jeep CJ Forum 0 09-17-2009 01:19 PM
CJ5 parts question Toddy Jeep CJ Forum 5 06-16-2003 03:41 PM
