CJs of the Month - Page 4 - JeepForum.com
Closed Thread
post #46 of 67 Old 10-03-2012, 06:11 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for October 2012!!
Congrats Jumphog!!
Originally Posted by Jumphog View Post
Specs
Year of CJ:
1986 CJ-7
Engine:
4.2L 258
Weber Carb
Hedman Hedders
Transmission:
T5 (rebuilt with stronger components)
Transfer Case:
Dana 300
Front Axle:
Dana 30
4.56 gears
Detroit Locker
Warn Lockout hubs
Rear Axle:
Currie Enterprises Dana 44
4.56 gears
Detroit Locker
1 piece alloy axles
11 inch brakes
Suspension:
4 inch Tough Country HD
2 inch body lift
Tires:
35 X 12.50 X 15 Cooper STT's
15 X 10 alloy rims
Additional Mods:
Magnaflow dual stainless exhaust
Warn M8000 winch on custom mount
Rhino lined tub
Full roll cage
Custom drive shaft (rear)
Custom tire carrier
Rock sliders/side bolsters
Skid plates on oil pan, trans/transfer case, fuel tank
21 gallon poly gas tank
Peerless wiring harness
Optima Red Top Battery
Besttop High-back seats
AM/FM/CD/MP3 in Tuffy Security console
Infinity speakers (front), KLH (rear)
Custom rear seat w/lockable storage underneath
Custom front and rear bumpers
Bestop softtop
Bestop bikini top
Custom stainless dash
Custom instruments
Flush mount LED tail and rear side lamps
Custom 4 inch receiver hitch
BESRK is offline
post #47 of 67 Old 11-05-2012, 07:32 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for November 2012!!
Congrats to Skerr!!!
Originally Posted by Skerr View Post
Specs
Year of CJ- 1979 CJ5
Engine- Stock 258 with MC2100, Team Rush, 80s model intake and exhaust manifolds
Transmission- Rebuilt T18A with Granny
Transfer Case- Rebuilt D20
Front Axle- WT D30 with 3.54 gears
Rear Axle- WT AMC20 with Superior 1-pc axles, Lockrite, 11" drums
Suspension- Bone-Jarring Rough Country 2.5" lift springs, ProComp 9000 shocks
Tires- BFG AT/KOs 33X10.5X15 on Soft 8s
Additional Mods- This was a first-time frame-off project for my son and I. It was taken down to the last nut and bolt and rebuilt. The tub, fenders, and hood are glass and required a great deal of work, including closing up the PO homemade tailgate. Tub has received the wheel-house notch and a 1" body lift. The windshield frame (metal) has been repaired and welded to remove rust holes. Axles were upgraded to WT from an '85 CJ7 for a better footprint. Regeared the axles to 3.54. My son made the bumpers, tire carrier, sliders, and roll cage. The A and B pillars were purchased from Extreme Custom Fab, a great product. Cage is tied into the frame at 6 points. Dash is custom with a gauge kicker panel that my son also made. Gauges are aftermarket SunPro (inexpensive but look good). Tilt steering column is from a 1979 1 ton Chevy, junkyard purchase and completely rebuilt. Custom battery box with ground buss. GrandAm seats mounted to cage. Corbeau 3-pt harness. LED flush mount tail lights. Paint is Mil-Spec Desert Sand and my first-ever paint job!
I would like to thank the Forum Members who donated materials and parts, EXCEPTIONAL parts, who without them and their caring, generous nature, this build would not have been possible! God Bless You, Guys!
BESRK is offline
post #48 of 67 Old 12-04-2012, 03:56 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for December 2012!!
Congrats to Hashbrown!!
Originally Posted by Hashbrown View Post
Specs
Year of CJ 1980
Engine Vortec 350
Transmission 475 hd lokar shifter manual valve body
Transfer Case 203/300 doubler with lomax and 4/1 with 3 sticks
Front Axle Dana 60 trussed arb locker, ctm u joints, cromoly axles, behind the axle full hydro steering, rock crusher diff cover
Rear Axle 14 bolt shaved and welded chromoly axles, solid diff cover, trussed with disk brakes
Suspension wishbone 3 link front and rear, poly performance shocks and coils
Tires 42" Irok stickies
Additional Mods Custom frame stretched to 121" wheelbase with a flat belly skid, mrw beadlock wheels, Custom cage, rockers, bumpers, and fenders ,warn 12,000 lb winch, corbeau baja ss front seats best top rear seat and 4 points, onboard air, fuel cell, cobra cb with kicker, 2000 watt inverter 200 watt amp with Wally World speakers, dual red tops, aluminum 3 core, electic fan, tranny, oil and steering coolers
BESRK is offline
post #49 of 67 Old 01-03-2013, 01:21 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for January 2013
Congrats to sanddrag!!
Originally Posted by sanddrag View Post
Specs
Year of CJ - 1984
Engine - Inline 6 cylinder 258ci
Transmission - T5
Transfer Case - D300
Front Axle - D30
Rear Axle - AMC20
Suspension - Rancho 2.5" springs, 1" lift shackles, RS9000 shocks.
Tires - Goodyear Wrangler MTR, 33x12.50
Additional Mods - Repainted and restored it myself, in original 3C Garnet Red Metallic. Custom fabricated front and rear bumpers and tire carrier, with frame tie-ins. Computerized Emission Control is all restored and passes smog superbly clean. Added factory air conditioning and electric onboard air compressor. "Team Rush" ignition upgrade. Sony xplod sound system with in-dash and rear speakers. Matching spare tire and wheel.
BESRK is offline
post #50 of 67 Old 02-04-2013, 07:06 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for February 2013
Congrats to JakeRod13!!
Originally Posted by JakeRod13 View Post
Here is mine...
Year of CJ : 1978 cj7
Engine : SBC 350
Transmission : T150 3 spd
Transfer Case : dana 30
Front Axle : dana 30
Rear Axle : amc 20
Suspension : 4'' skyjacker
Tires : 33'' ats with 15'' Mickey Thompson II
BESRK is offline
post #51 of 67 Old 03-02-2013, 06:02 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for March 2013
Congrats to addicted2dunes!!
Originally Posted by addicted2dunes View Post
Specs
Year of CJ: 1981 Scrambler
Engine: 4.0L EFI
Transmission: 42RE
Transfer Case: Dana 300
Front Axle: Dana 44HD
Rear Axle: Dana 60
Suspension: Custom
Tires: 37" Humvee (Goodyears)
Additional Mods: Almost everything
BESRK is offline
post #52 of 67 Old 04-02-2013, 06:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for April 2013!!
Congrats to SCJeepr!!
Originally Posted by SCJeepr View Post
It has been a long time since I submitted so I figured what the hey!
Specs
Year of CJ - 1982 CJ8 Scrambler SR
Engine - 258 w/ TBI
Transmission - T4 Speed
Transfer Case - Dana 300
Front Axle - Dana 44
Rear Axle - Dana 44
Suspension - 4" Springs with front reversal and 2" shackles
Tires - 35x12.5-15 Procomp Xterrains on American Racing Bajas
Additional Mods - Where to start.....PSE Steering Box, Custom Rockers, 6" Xenon Flares, Lined Interior, Mastercraft Seats, Stereo w/ indash and 6x9 for the rear, custom rear bumper with swing and high light jack mount, full hard top, half hard top w/ bulk head, full soft top, half soft top, rear levis seat, half steel doors with TJ uppers, Full Steel doors, original CJ 2 Piece soft doors, Original 1 piece soft door customized and recovered for use with hard tops as well as soft tops, custom striping to fit the flares and more that I just can't think of right now I'm sure.
Winter Mode
Summer Mode
BESRK is offline
post #53 of 67 Old 05-02-2013, 04:23 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for May 2013
Congrats cj7ole!!
Originally Posted by cj7ole View Post
Year of CJ: 1984
Engine: '07 5.3 Chevy drive by wire, Flex Fuel
Transmission: 4L60e rebuilt to 4L70e internals
Front Axle: Stock w/Warn Hubs
Rear Axle: AMC 20 w/Detroit Locker and Moser solid axles 4.10 gears
Suspension: 2.5" SkyJacker
Tires: 33"x12.5"-15 Hercules Trail Diggers on American Racing AR23's
Additional Mods: 2 piece Tom Woods front driveshaft, rear Tom Woods driveshaft, 1" body lift, fiberglass body, hood and fenders, Magnaflow open muffler, K&N air filter, Carter P5000 fuel pump, Corvette C6 exhaust manifolds, custom Griffin radiator, Wayne Hartwig (150tunes.com) chip tune and wire harness rebuild, House of Kolor Tangelo Pearl done in my garage, custom rear tire/kayak carrier, 6,000 pound Ramsey winch, Borgeson steering shaft, aluminum dash, Wet Okole Hawaii neoprene seat covers, Body Armor front bumper w/custom Tangelo D-rings, rear receiver hitch w/custom Tangelo D-ring, TANGELO license plate, Stewart Warner mechanical oil and temperature gauge and SW gas gauge, ScanGauge II, bikini top, Bestop full top, Olympic front light bar to support Thule kayak pads, Carr aluminum "Mama" step, POL Raptor bedliner, Optima Yellow Top battery. No radio, no A/C.
History: My son, Jason (Big Jake to his ironworker friends) bought it in 1990 while in high school. With mostly my money and wrenching together we did somewhat of a frame up restoration adding a Chevy 4.3 with a Howell Engineering harness, advance adaptors engine mounts and bell housing, fiberglass tub, fenders and hood, painted it Purple Passion, raised it 3.5" yadda, yadda. In 1996 he won the winch at the Cadillac MI Jeep Jamboree. Since then, we mostly take it out on nice days, ride the 2 tracks up north and use it at the Silver Lake Dunes. I tow it to FL in the winter behind my 33' Winnebago to use to get around down there for 2 months. Added a kayak rack and did a full paint job in 2009, HOK Tangelo Pearl with the black POL Raptor bedliner interior. In 2011 we installed a 5.3 out of an '07 Tahoe with the 4L60e tranny, mated to the original Dana 300. Pulled a noobie who didn't know the difference between the clutch and brake pedal on stuck Ford PU off the top of Test Dune at Silver Lake in 2011, he smashed into our SS bumper, thus the new Body Armor front bumper.
BESRK is offline
post #54 of 67 Old 06-07-2013, 06:53 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for June 2013
Congrats Tweeter00801!!
[quote=Tweeter00801;15490877]Specs; CJ7
Year of CJ: 1978
Engine: Original AMC 304
Transmission: Stock T-150
Transfer Case: Stock Spicer 20
Front Axle: AMC 20
Rear Axle: AMC 20
Suspension: 4 Inch Rough Country Suspension Lift
Tires: 33x15.5 Interco Superswampers
Additional Mods: 304 Stainless Steel Dash Panel, Windshield Motor Cover, and Windshield brackets. Rhino lined interior and underside of the tub. Non-Standard silver Jeep and Renegade Stickers. Custom heavy duty front and rear bumpers.
[/quote
BESRK is offline
post #55 of 67 Old 07-02-2013, 05:36 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for July 2013
Congrats to CooterBrown!!
Originally Posted by CooterBrown View Post
Old Red
Year: 1965
Engine,tranny,etc all stock
Tires: cooper atr on American racing wagon wheels.
No mods other than my sick grenade shift knob haha
BESRK is offline
post #56 of 67 Old 08-06-2013, 07:21 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for August 2013!!
Congrats to Manhattan!!
Originally Posted by Manhattan View Post
1981 CJ8
5.7 TPI, First Fuel Injection, All Brackets Powder Coated By Smoking Gun
W.O. Tub, Rotisserie Painted in Single-Stage, No-Metal Custom Mix
SM465
Twin-Stick Dana 300
Dana 30, 4.56 Gears, Detroit Locker, Warn Axles
Model 20, 4.56 Gears, Detroit Locker, Moser Axles
R.E. 4.5, Braided Lines, M.O.R.E. Shackles, 1 BL
35 BFG MTs on Chrome Wagons
Additional Mods: Double-D Dash with AutoMeter Guages, Family Cage with Rear Seat 3-Point Belts - Tied to Frame, Rock Rails and Rear Bumper; U-Shaped Rear Bumper; Integrated Bed Rock Rails; Rock Rails Tied to Frame and Cage
BESRK is offline
post #57 of 67 Old 09-04-2013, 07:11 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for September 2013
Congrats mtndew1!!
Originally Posted by mtndew1 View Post
Here is my 1976 CJ7:
Specs:
Engine: AMC 304 - stock rebuild with mild cam (comp)
Transmission: Hughes Performance AMC TH400
Transfer Case: Dana 300 (4:1) & Twin Stick
Front Axle: Dana 30 - 4.56 & ARB
Rear Axle: Front HP Dana 44 with rear outer tubes and reverse cut gears - 4.56 & ARB
Suspension: Rubicon Express 4.5 spring under
Tires: 35x12.5 KM2's on Single Beadlocks
Additional Mods:
Custom Paint by me (never again)
Custom Cage by Hunter Off-road 100% DOM and tied to frame @ A and B
Custom Roof by Hunter Off-road
Custom Tire carrier by Hunter Off-road with full front spindle, hub, disc spare parts built in.
Custom Center Billet Console
Custom Dash by Double D Fab
Genright Aluminum Highline CJ Fenders with YJ non Highline aluminum inner fender wells.
Genright Rocker Guards
Master Craft Seats with RCI Harness
Rebuilt Warn 8274
Rigid Industries 50", 20" and 10" SR Series LED Bars
Vanco Hydroboost
Click for big Images:
BESRK is offline
post #58 of 67 Old 10-04-2013, 07:04 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for October 2013
Congrats bradleybrb!!
Originally Posted by bradleybrb View Post
Hope I am doing this right.....here goes nothing!
Specs
Year of CJ - 1975
Engine - 304
Transmission - T14
Transfer Case - dana 20
Front Axle - dana 30 3:73 gear
Rear Axle - dana 44 3:73 gear with track loc
Suspension - factory springs re-arched to have aprox. 2-3" lift
Tires - 33x12.5 Kelly Safari
Additional Mods - pretty much stock except for, split duration 256/263 Bullet cam, Edelbrock preformer intake, Edelbrock carb, headers, Black Rock Viper wheels, bedliner spray inside and underneath by me, factory apple green paint by me (basecoat/clearcoat), Equis gauges except for speedometer assembly which I also had white faced to match, Centerforce 2 clutch, seats and dash pad custom re-covered by my aunt
BESRK is offline
post #59 of 67 Old 11-02-2013, 06:59 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for November 2013!
Congrats Krum81!!
Originally Posted by Krum81 View Post
Specs
Year of CJ 1975
Engine AMC 360
Transmission T18
Transfer Case DANA 20
Front Axle 4.27 WAGONEER D44 W/DISC
Rear Axle 4.27 ORIGINAL D44 W/POWERLOCK
Suspension ROUGH COUNTRY 4" WITH 1/2 SHACKLES
Tires BFG 35.12.50 X 15
Additional Mods TBI INJECTION MOTOR, HECULINER TUB , REAR SEAT IS SPEAKER BOX W 10" SUB,FRONT BUCKET SEATS, POWER STEERING,TILT STEERING, POWER BRAKES, LED TAIL LIGHTS, FACTOR STEEL HARDTOP WITH GLASS WINDOWS ALL TINTED BUT FRONT WINDOW.
[IMG][/IMG]
[IMG][/IMG]
BESRK is offline
post #60 of 67 Old 12-20-2013, 05:50 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ of the Month for December 2013
Congrats G-FOURce!!!
Originally Posted by G-FOURce View Post
Why not, right?!
Year of CJ...1986
Engine...258 i-6
Transmission...T5
Transfer Case...Dana 300
Front Axle...Dana 30
Rear Axle...AMC 20
Tires...BFG 31/10.5/15
BESRK is offline
Closed Thread
CJ of the Month Submit Now.. Feb 2010 CJ of the Month BESRK Jeep CJ Forum 0 01-02-2010 08:21 PM
Cj Of The Month This Month! JeepHammer Jeep CJ Forum 1 01-14-2009 07:13 PM
Feb CJ of the Month BESRK Jeep CJ Forum 2 01-01-2009 10:53 PM
CJ of the Month BESRK Jeep CJ Forum 27 11-11-2008 08:03 PM
CJ of the Month Jayson44 Jeep CJ Forum 0 11-10-2008 01:07 PM
