CJ8 front drive shaft - JeepForum.com
post #1 of 5 Old 11-11-2012, 08:54 PM Thread Starter
twbish5
I recently purchased a 1982 CJ8 (Dana300 transfer case / Dana 30 front axle) and the guy did the 4.0L swap in it. He never installed a new front drive shaft and ive been told that i can't use a OEM one because it won't fit after the swap. Does anybody have any reference or experience on this?
twbish5 is offline
post #2 of 5 Old 11-11-2012, 09:05 PM
cookingguy
1979 FSJ Cherokee
You should still be able to use the stock shaft. The transfer case has nothing to do with the engine as far as i can tell. I say climb under and put it all in place if it fits right ur good to go
cookingguy is offline
post #3 of 5 Old 11-11-2012, 09:06 PM
John N
1981 CJ8
The OEM one should fit, unless the trans was swapped too. A 4.0 takes the same space as the OEM 258 engine, no moving back or forward.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 5 Old 11-12-2012, 02:42 AM Thread Starter
twbish5
ok thanks guys. I was going off rumors i heard but nobody could confirm for me
twbish5 is offline
post #5 of 5 Old 11-12-2012, 07:31 AM
CSP
So did he leave the stock transmission in place?
CSP is online now
cj , dana 300 , drive shaft
