Cj7 Wont Turn Over!!! Help Plz - JeepForum.com
post #1 of 30 Old 01-18-2010, 11:22 PM Thread Starter
cgi2099
Okay here is the story, had been driving my jeep around all day two days ago starting it on and off as need be, and i go to start it one time, hear a semi load pop and it wont turn over. So the first thing i do is change the solenoid and it fixes it, at least for a little while. Today same thing happen, so i go and warrant out my new solenoid but this time it doesnt fix my problem (will still start if i push start it thank god its a manual). So im asking what could be the problem. Im thinking maybe the ignition module but i dont want to replace it if thas not the cause seeing as its 100bucks. Another thing is, it will crank if i jump across the solenoid but wont start up(with key on) and the nutter bypass has been done with a autolite 2100 installed.
cgi2099 is offline
post #2 of 30 Old 01-19-2010, 07:02 AM
Mike Romain
OK... Lets try to sort it out.
It 'will' run if you push start it with the key to 'run', right.
It will not turn over at all with the key, it's just plain dead.
It will not run with the key in 'run' and the solenoid jumped to crank the starter over.
Is that about right?
Mike
Mike Romain is offline
post #3 of 30 Old 01-19-2010, 11:12 AM Thread Starter
cgi2099
Took a closer look at my problem today and found that the blue starter wire(im guessing because the solenoid says "s") was all junk up so i put a new connector and and sanded all the terminals down and it cracked over and started up like normal but while i was taking a closer look i found some new problems. There are three black wires(one having a white strip) that come out of the same harness that is going to the alternator and solenoid that look like ground wires to but but im not sure and don't know where they, was wondering if anyone could help.
Here is a picture:
cgi2099 is offline
post #4 of 30 Old 01-19-2010, 01:23 PM
Mike Romain
There are a bunch of spare wires on a CJ, for AC to name just one thing you don't have.
Just look at the condition of them, they are dirty. If they were ever on someplace, they would be clean and have nut or washer marks on them.
Mike
post #5 of 30 Old 01-19-2010, 02:34 PM Thread Starter
cgi2099
Do you know of any grounds that are suppose to come out here? Everything is original on the jeep, only mods to it have been by me. Which include removal of emissions junk, nutter bypass and autolite 2100.
cgi2099 is offline
post #6 of 30 Old 07-19-2014, 08:06 AM
bkvanbek
I have a similar problem. My 1984 ran great for a couple days after bringing it out of extended storage. Then would click when I turned the key but would not turn over. I jumped the solenoid and it would turn over. I replaced the solenoid and now nothing
bkvanbek is offline
post #7 of 30 Old 07-19-2014, 08:38 AM Thread Starter
cgi2099
Mine ended up being the starter switch mounted on the steering column.
cgi2099 is offline
post #8 of 30 Old 07-19-2014, 08:55 AM
aaronjwood
1978 CJ7
Here is a picture:
A tad off subject here, but when was the last time you changed your oil filter? It looks like it could be original If you don't change it soon, your Jeep is going to "not run" for a bunch of other reasons...like a spun bearing for example.
Need a floor jack? - Check out our reviews
aaronjwood is offline
post #9 of 30 Old 07-19-2014, 09:01 AM Thread Starter
cgi2099
Lol that picture was after I first bought the jeep, its been changed at least 5 times since.
cgi2099 is offline
post #10 of 30 Old 07-19-2014, 09:06 AM
bkvanbek
I jump over the new solenoid and it cranks won't start. & I find I have no lights clock or anything electronic
bkvanbek is offline
post #11 of 30 Old 07-19-2014, 09:06 AM
aaronjwood
1978 CJ7
Whew! You had me sweating over here.
post #12 of 30 Old 07-19-2014, 09:23 AM
bkvanbek
how can I diagnose this further?
bkvanbek is offline
post #13 of 30 Old 07-19-2014, 09:27 AM Thread Starter
cgi2099
Check all your fuses, but it still sounds like starter switch to me. Same synmtoms and everything.
cgi2099 is offline
post #14 of 30 Old 07-19-2014, 09:51 AM
keith460
Jeep. There's Only One
keith460's Avatar
Battery cables corroded or poor grounds IMHO.
1984 CJ-7 Renegade
keith460 is offline
post #15 of 30 Old 07-19-2014, 10:11 AM
row684
Stick a test light in the end of the plug that goes on the solenoid turn the key to "start" light should come on. Might need a friend to help.
I'm betting it doesn't light up in which case you need to do a similar test on the switch in the column. Make sure it's getting power in and sending power out.
row684 is offline
85 CJ7 will crank but wont turn over? HRW85CJ7 Jeep CJ Forum 18 09-29-2009 03:42 PM
74 cj5 401 will crank but wont turn over sherman401 Jeep CJ Forum 6 06-03-2009 04:47 PM
Wont turn right ! help? jbeenz Jeep CJ Forum 15 12-22-2006 07:09 PM
ok so i got it to turn over but it wont run bkeast17 Jeep CJ Forum 11 07-04-2006 07:41 PM
jeep wont turn over Fuzz21 Jeep CJ Forum 6 12-27-2005 04:53 PM
