CJ7 wont start when hot - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ7 wont start when hot
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDJK Vent Covers - NalinMFGTJ 5.25" Speaker Adapters - NalinMFG
Unread 06-25-2014, 05:34 PM   #1
87MJTim
1987 MJ Comanche
84 CJ7 258 T5
I got it last fall and have been driving it on the weekends mostly. The last few weeks I have driven it during the day to run some errands. After a quick stop, I get in and try to start it, but I get two problems. First, some times the starter just makes a grinding noise and wont turn the engine. I will begin by replacing it.
Second, when the starter does turn the engine, it just cranks and cranks but will not fire. Sometimes it sounds like it want to fire but just doesn't.
After several tries, it finally turns over. It runs just fine after this.
I have read several threads on JF with similar issues, but the OP does not give a final resolution that fixed the issue.
Some of the possible causes: engine heat effecting the starter (but the starter will turn the engine), heat effecting the solinoid, or vapor lock. Are there other issues to look for?
Have others had this problem? What did you do to fix it?
Tim
87 Comanche, 4.0, BA10/5, D44
84 CJ7, 4.2, T5
87MJTim is offline   Reply With Quote
Unread 06-25-2014, 06:50 PM   #2
RenoF250
Mine did the same. Not sure what it is put I would just push the pedal to the floor while cranking and it would start. New starter should fix the other problem.
RenoF250 is offline   Reply With Quote
Unread 06-25-2014, 06:55 PM   #3
lucdog
lucdog's Avatar
1980 CJ5
I would start by cleaning all the electrical connections from the battery, to the solenoid, starter and block. Start with the positive on the battery, then leave that one disconnected until done, then reconnect it.
With a carburetor , I normally hold the gas pedal down a 1/8th to a 1/4 of its travel when starting hot.
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote
Unread 06-25-2014, 06:59 PM   #4
LumpyGrits
Try another battery
Have the starter ck'd out and make sure ALL ele. connections are clean and TIGHT.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 06-26-2014, 05:43 AM   #5
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Too much timing can also cause hard hot starts.
Matt
Matt1981CJ7 is online now   Reply With Quote
Unread 06-26-2014, 08:21 PM   #6
carnuck
1984 J-Series Truck
It will also do this when the 12 volt pickup on the solenoid wears off. To test, put a testlight on the "I" terminal of the solenoid and it should light while the motor is cranking. If not, then it's worn off. Voltage drops too much while cranking (because it passes through an ignition resistor wire) leaving you with not enough spark when the starter is turning slow from heat soak.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 06-26-2014, 09:04 PM   #7
87MJTim
1987 MJ Comanche
Matt
What timing marks should I set it to?
Tim
84 CJ7, 4.2, T5
Unread 06-27-2014, 03:21 AM   #8
86cj74.2L
86cj74.2L's Avatar
With the engine warm and idling look into the carb throat for fuel dripping out if the upward turned brass tubes in the Venturi cluster.
86cj74.2L is online now   Reply With Quote
Unread 06-27-2014, 04:25 AM   #9
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Mine likes 9. The numbers are hard to see, the lines are 2 each starting with +2 on the far right.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 06-27-2014, 05:17 AM   #10
Matt1981CJ7
1981 CJ7
If your engine is Nuttered, 6-8 degrees BTDC, with the vac advance hose disconnected and plugged, should be about right for your elevation.
Matt
Unread 06-27-2014, 06:05 AM   #11
87MJTim
1987 MJ Comanche
Matt
I don't know if it was Nuttered. The PO did put on a MC2150 and a diff dizzy. He removed alot to the vac system/hoses. Nutter?
Tim
84 CJ7, 4.2, T5
Unread 06-27-2014, 06:44 AM   #12
Mike Romain
What kind of dizzy? Nuttered just means the emissions computer is no longer controlling the timing.
Mike
Unread 06-27-2014, 11:08 AM   #13
86cj74.2L
86cj74.2L's Avatar
With a MC forget the above. I wondered if you had fuel drip causing a flood condition
Unread 07-20-2014, 04:24 PM   #14
87MJTim
1987 MJ Comanche
I want to give a follow up. I have not worked on the CJ since I last posted - work, life and vacation interupted what's important.
I dropped the oil pan today to fix the oil leak it has had since I picked it up last Sept. I pulled off the starter to examine it. The "drive gear" (if that is what it's called) was loose. It could move side to side a little and back and forth approx. 1/8". When I shook it, I could hear parts rattling inside. I got a new (reman) from NAPA. No loose parts! Also got a new solenoid.
I have not finished the oil pan gasket change. I will post results when I complete the work.
Thanks for all your suggestions and comments.
Tim
84 CJ7, 4.2, T5
Unread 08-20-2014, 07:01 PM   #15
BinTinBoynio
Tim, what happened? My CJ7 is also not starting when hot and was wondering if your problem had been solved and with what fix.
BinTinBoynio is offline   Reply With Quote
