cj7 windshield cowl gasket - JeepForum.com
post #1 of 5 Old 05-04-2013, 10:37 PM Thread Starter
treylt
1982 CJ7
Can anyone suggest a brand of gasket that works well. im about to replace mine and want to be sure to buy a quality gasket
treylt is offline
post #2 of 5 Old 05-04-2013, 10:41 PM
ironbyron1
1977 CJ5
I bought mine from Morris 4x4. I think it is a Crown. It installed perfectly. I'm gonna have to go back and fill the rusted out portions of my winshield/cowl with silicone to keep it from leaking all together though.
Byron Oost
Owensboro, Kentucky
ironbyron1 is offline
post #3 of 5 Old 05-04-2013, 11:12 PM Thread Starter
treylt
1982 CJ7
thanks for the info!
treylt is offline
post #4 of 5 Old 05-05-2013, 04:21 AM
82JeepCJ7
1982 CJ7
When I put my new gasket in, it had expanded and was "too thick" so it seemed. After it was secured to the bottom of the windshield frame, I loosely installed the hold down hardware on each end. I had to pull the frame back/down to get it where it should of been. I used ratchet straps hooked to the top corners of the frame on one end and the seat frame on the other. I slowly compressed the frame back down until it was aligned with the hold down. I checked the angle with my hard doors to ensure it was correct. I then tightened down my hold down hardware. I have yet to fold it back forward....
After it was all tied down, I ran a small bead of black silicone along the outside to seal the seal to the frame. To date I have not had any leaks where my feet used to get wet every time it rained.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 5 Old 05-05-2013, 06:21 PM Thread Starter
treylt
1982 CJ7
Good info. This seems to be a common problem. Thanks for your reply
treylt is offline
