Cj7 weight? Too much for air shocks?? - JeepForum.com
post #1 of 4 Old 04-26-2013, 02:29 PM Thread Starter
cj7350
Hey guys, I'm building a 79cj7 with a 350/700r4/241 in it all on tons and 4 linked, and need to know if fox 2.0 air shocks would work. They say 500LB per corner max for the 2.0s but I can't find the weight of a cj with 350 minus the axles. Iv plated some of the frame with 1/4" plate for strength, and will be adding a pretty beefy roll bar set up. That's about all I'm adding weight wise. I like the 2.0 for the price and I'm not gonna run coils just for the simplicity and less suspension parts under the jeep. Let me know what y'all think, thanks guys
cj7350 is offline
post #2 of 4 Old 04-26-2013, 04:53 PM
WindKnot
1977 CJ7
If you fill out the profile we can look at it and answer questions. When it's blank we don't know what year it is, which transmission it is, etc.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 4 Old 04-26-2013, 08:00 PM
jumbojeepman
1976 CJ7
500 lbs per corner is only a 2000 lb car (- axles and wheels/tires.) A Jeep weighs more than that per corner. Wheels and tires are probably 75 pounds each, and a front or rear axle is probably around 200 lbs (because I can pick one up.)
jumbojeepman is offline
post #4 of 4 Old 04-27-2013, 11:46 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Shock towers are not designed to carry weight. Installing air shocks, especially to raise the ride height or for towing almost invariably leads to tower breakage. This is why air shocks have somewhat gone the way of the dinosaur.
Back in the day, when they were still popular, it was not uncommon to see an car or truck dragging a shock around with the bottom stud still hanging out of the eye.
jeepdaddy2000 is offline
