CJ7 Weber vs. Holley - JeepForum.com
post #1 of 5 Old 05-01-2011, 05:00 PM Thread Starter
mcollins-az
I have an 82 cj 7 (258) running offenhauser intake with holley 390 cfm. I'v always had problems with the holley. Has anyone run the weber carb on the offenhauser dual port 4 barrel intake? Is it possible to adapt the weber to the 4 barrel intake?
mcollins-az is offline
post #2 of 5 Old 05-05-2011, 11:27 AM
Rowinj13
1978 CJ7
What sort of problems have you been having with the holley. I have the 390 on the offy intake, and it has taken me a lot of tinkering to get it just about right. Jeephammer has a great write up about getting holley carbs set up, and making non truck avenger models almost as good as the TA's. I had toyed with the idea of going to a Weber but I already have the Holley and with a little time and patience you can get it working pretty well. Let me know what is going on and I can try to help.
'78 CJ7 4.2L, Dana 30 AMC 20 (3.54 Open), Dana 20, T150, Holley 390 cfm, Offy Intake, Headman Header, Team Rush upgrade, 31x10.5x15 Custom Cut Cooper Discoverer ATR's. Custom front and rear bumpers, Fiberglass tub and front clip, PO had the Engine Rebuilt in 1995. ~Visualize Using Your Turn Signals!~ Instant Gratification Takes Too Long!
Always tell the truth, that way you never have to remember what you said!
Education will take you so far, Common sense will carry you the rest of the way!
Rowinj13 is offline
post #3 of 5 Old 05-05-2011, 11:31 AM
superj
i have a weber 34 i am about to swap for a motorcraft. i will swap you for your holley because i want to run a different intake later on
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 5 Old 05-07-2011, 09:09 PM Thread Starter
mcollins-az
CJ 7 Weber vs. Hollwy
Thanks for the two replies.
I finally got the jeep to run, but it was knocking and running terrible. I pulled the valve cover to find 3 bent rods??? I am going to replace rods and see what happens. I would imagine this was due to sticky valves. We'll see?
post #5 of 5 Old 05-08-2011, 06:16 AM
Viencent
1982 CJ7
have you looked at going TBI? did this 2 months ago and dont miss the carb at all on my 304
Viencent is offline
Weber 38 vs. Holley manifold & 4 barrel. Taking2long Jeep CJ Forum 36 07-27-2015 11:31 AM
holley or weber travisoneil Jeep CJ Forum 0 05-01-2011 09:09 AM
Weber Holley or Motocraft? b.d.d. Jeep CJ Forum 4 11-23-2007 02:56 PM
Redline Holley Weber 32/36 jetting? 52pu Jeep CJ Forum 5 06-08-2007 01:45 AM
Weber or Holley From78To83 Jeep CJ Forum 3 12-06-2004 02:35 PM
