Cj7 + vw tdi - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cj7 + vw tdi
*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*The Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 02-16-2013, 08:14 PM   #1
CJ7TDI
Cj7 + vw tdi
Hi im planing to buy and build my first 4x4 a 1980-1986 Jeep Cj7 Laredo 4.2 I6 that i will install a VW 1.9 TDI PD
there are two adapter that i have been thinking of
The ACME adapter to a toyota A340F 4 speed automatic but not sure if the dana 300 will connect to it?
or
The HPA Motorsports Inc. adapter and a Jeep NSG370 6 speed manual that fits the Dana 300
will also do the tj grill, what suspension do you recomend and should i do a shackle lift? do you have any suggestions on the build? Thanks
CJ7TDI is offline   Reply With Quote
Unread 02-16-2013, 08:44 PM   #2
Cutlass327
Cutlass327's Avatar
1978 CJ5
Why are you going to put a TJ grille on it?!? Might as well get a TJ.
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote
Unread 02-17-2013, 05:15 AM   #3
Jeeprage
I agree. If you prefer the look of the TJ, then pick up a 4 cyl with a blown engine. Not going to have the same just issues as a CJ, and will ride better with coil suspension.
I think HPA kits are more geared towards Wranglers to begin with.
No TJ bashing from me, but I'd only consider that swap with a TJ. You'll have an all around better driver if you are looking to use it daily.
2005 WK Limited 5.7 - SRT8 swaybar, Bilsteins, Superchip
1986 CJ7 build thread - Nuttered Holley 258, T5, D300, D30/D44 locked 2.73, 4wd fiberglass tub, 3" BD lift with OME shocks, 33" Duratracs - IT DRIVES!
Jeeprage is offline   Reply With Quote
Unread 02-17-2013, 10:06 AM   #4
CJ7TDI
yes it is a better option to get the tj but the problem is that here in Colombia SA vehicles are very expensive for example the cheapest in there class are a cj7 cost 10,000000 COP
= 5,000 USD , YJ 22,000000 COP = 11,000 USD , 06 TJ 45,000000 COP = 22,000 USD , and a 07 JK 58,000000 COP = 29,000 USD. and they dont devaluet if they have a bad
engine they fix them. i might look in to a YJ found one for 17,000000 COP = 8,500 USD negotiable. well look at this video on FB of a CJ7 with the HPA kit http://<br /> <br /> https://www.fac...09332339140428
Unread 02-17-2013, 12:18 PM   #5
Jeeprage
engine they fix them. i might look in to a YJ found one for 17,000000 COP = 8,500 USD negotiable. well look at this video on FB of a CJ7 with the HPA kit http://<br /> <br /> https://www.f...09332339140428
Your profile says PA, USA... Any older TJs? They started in 97.
Unread 02-17-2013, 12:43 PM   #6
CJ7TDI
yes i also live in PA, USA but in the summers. yes but look at the wranglers that i can chose from http://carros.mercadolibre.com.co/je..._OrderId_PRICE
and here are the cj some are lables incorrect so look by the year
i will ask for them out there as well.
Unread 02-17-2013, 12:47 PM   #7
Jeeprage
yes i also live in PA, USA but in the summers. yes but look at the wranglers i can chose from http://carros.mercadolibre.com.co/je..._OrderId_PRICE
I have no idea what other cars are priced at for you either, or why this is the full selection of what you can look at, but at those prices, I wouldn't own a Jeep.
Good luck!
Unread 02-17-2013, 01:06 PM   #8
CJ7TDI
jajajaja all vehicles are this price here because import taxes are a scam in this country. was looking at 2013 Nissan B13 asembled in mexico that cost 12,000 USD but its a sedan and will get stuck anywhere with the roads that are in this country.
Unread 02-17-2013, 02:00 PM   #9
CJ7TDI
well i have desided to look for a YJ 88-95 because it will be better ride over the cj7. i will go with The HPA Motorsports Inc. adapter and a Jeep NSG370 6 speed trans that connects to the NP231 tcase
Unread 02-17-2013, 03:38 PM   #10
Cutlass327
Cutlass327's Avatar
1978 CJ5
Are YJ driverside drop or passenger side like CJs are? Np231 are driver side IIRC.
Rick
Unread 02-17-2013, 03:42 PM   #11
lucdog
lucdog's Avatar
1980 CJ5
YJ= drivers drop
Bill
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote
Unread 02-17-2013, 05:04 PM   #12
Cutlass327
Cutlass327's Avatar
1978 CJ5
OK, thanks for the correction!
Rick
Unread 02-17-2013, 06:31 PM   #13
bajaviking
Why do you think a YJ will ride nicer than a CJ7? They have same wheelbase and both use leafsprings front and rear.
85 CJ7 4.3L FI/700R , 4:1 Dana 300 and 3/4 ton diffs.
76 CJ7 6 cyl/t18/Dana 20 pretty much stock
"It ain't been so easy but I guess I shouldn't complain,
I've always been crazy but it's kept me from going insane"
bajaviking is offline   Reply With Quote
Unread 02-17-2013, 08:14 PM   #14
CJ7TDI
because its a newer. sorry didnt mean how it rides
Unread 02-17-2013, 08:45 PM   #15
lucdog
lucdog's Avatar
1980 CJ5
YJ springs are flatter and give a better ride than CJ springs.
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
