cj7 v-8 swap - JeepForum.com
post #1 of 5 Old 07-02-2002, 01:54 AM Thread Starter
darkcornercustoms
Post cj7 v-8 swap
HEY EVERYBODY! ok, my friend bought a cj7 with a awsome body and a 4cylinder (boo!) now i don't know much about jeeps but i thought this 4-banger would suck....not the case. i was seriously impressed by the torque produced by that little engine. aniways i digress..he wants to do a 350 swap. i have friends with 4x4 shops and i am getting help but i need to know if anione makes a good cheap bolt in motor mount kit. any help here would be great. i put a 350 in an s-10 blazer and bought the mounts for around $90 so i wouldn't think they could be much more than that. more posts to follow on tranny fitment and x-fer case selection /fit /i don't know what the heck i'm doing oh well..i'll figure it out. i hope you can help.
brian
darkcornercustoms is offline
post #2 of 5 Old 07-02-2002, 02:08 AM
Hippo393
Thumbs up
Well congrats on your friend's purchase and welcome to the Cj board. Which motor mount bolt? My mount bolts are 2 different sizes -- a longie and a shortie for each. I suppose if I was desparate I could take the mount to a hardware store and find a bolt to fit it. Is that possible in your sitch?
Hippo393 is offline
post #3 of 5 Old 07-02-2002, 05:48 AM
Bulletproofcj7
Post
<a href="http://www.advanceadapters.com/aa.com/mounts/jeep.html" target="_blank">http://www.advanceadapters.com/aa.com/mounts/jeep.html</a>
<a href="http://www.mountainoffroad.com/catalog/BombProof%20MM/bombproof.htm" target="_blank">http://www.mountainoffroad.com/catalog/BombProof%20MM/bombproof.htm</a>
Here are links to a couple of sites that sell 350 conversion motor mounts.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #4 of 5 Old 07-02-2002, 08:55 PM
Franken-Jeep
Franken-Jeep's Avatar
Post
I just put a 350 in my CJ7. I had a friend of mine custom make motor mounts and weld em in. But as the previous post states, you can buy them too. The 350 I got was from a truck so I got the tranny, and T-Case were all together. The Tranny is a TH350 (Turbo 350) and should be considered instead of a TH400 as it is several inches shorter and may fit better. Espicially a CJ5. Rewiring the engine is my biggest concern as I have never done this. Also, consider the custom drive shafts your friend will need from the GM T-case to the differentials. To have them made is $250 or so, unless you get them from a bone yard and make them yourself.
Good Luck - Hope this helps a little.
Greg
1981 CJ7 FOR SALE - rebuilt from the ground up....check out my web page for details. http://www.bmw-m3.tv/jeep.html
Franken-Jeep is offline
post #5 of 5 Old 07-03-2002, 01:59 PM
Happypappy
Post
Of course another way to go that usually costs less and provides great results as well is to go with an AMC V-8. All the parts are plentiful and not very expensive.
The 360 (for example)provides plenty of power, lives forever and is easy to work on when the need arises.
C. Lynn
Applications Engineer
Computerized Marine Diesel, IPS Systems
'06 Rubicon Unlimited
Happypappy is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
yj tub swap on cj TravellinMan_15 Jeep CJ Forum 1 03-29-2009 04:14 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
