CJ7 Turn Signal Wiring Problem - Page 2 - JeepForum.com
post #16 of 17 Old 08-20-2012, 02:32 PM
DENVAR03
THANK YOU!!!!!!
I will bet you don't even know how much you help us novice's,when we just read all your great posts,and figure them out!!!!!.you are a "BIG" PART ,of our success,in restoring our CJ'S.
thanks
DENNIS
DENVAR03 is offline
post #17 of 17 Old 09-14-2012, 07:49 PM
aggiejon
1979 CJ7
The fuse box is just riding piggy back on the bulkhead connector. You can relase some clips and move the fuse box out of the way.
Test light is the best way to quickly trouble shoot this problem if your grounds are good. A bad ground can also fool a test light.
Here is a picture of the steering wheel connector BagusJeep has mentioned. A good place to start.
Here is some more tips:
http://www.jeepforum.com/forum/f8/tu...witch-1225607/
Relocated my ignition switch to the dash using a universal switch. Got tired of the cylinder falling out all the time. In the process, I ran new ignition wiring from underhood to the key. After this, my steering column bulkhead that houses the turn indicators (as well as likely other essential marker and indicator lights) have ceased to work. This is most likely since my ignition switch is no longer used on the dash.
My question is where on that plug, or on the column can I splice into my new ignition wire to trick the column plug into thinking the key is on and power the lights? Thanks
jg
aggiejon is offline
cj7 , fuse diagram , wiring
Chieftian Turn Signal wiring help.. doctordave Jeep CJ Forum 13 04-02-2013 02:48 PM
72 cj5 turn signal wiring heatmiza Jeep CJ Forum 3 07-25-2011 04:06 AM
Turn Signal Wiring on 75 CJ-5 chosen1608 Jeep CJ Forum 1 05-04-2010 01:53 PM
turn signal wiring jhedges15 Jeep CJ Forum 9 03-02-2010 06:15 PM
Turn signal problem OldSailor Jeep CJ Forum 4 04-23-2008 12:37 AM
