CJ7 Transmission Question. - Page 3 - JeepForum.com
post #31 of 45 Old 04-30-2013, 01:10 PM
Stormpaw
1983 CJ7
Oh, I forgot... the AX15 is a stronger transmission than the AX5 or SR4 (I am guessing that is what you currently have), and compatible with the AMC I6 with just a little work, and the Dana 300 with an adapter.
However, getting smaller axle gears would achieve pretty much the same result (other than the stronger transmission case.)
Stormpaw is online now
post #32 of 45 Old 04-30-2013, 01:16 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
Originally Posted by frhrwa View Post
why aren't you considering the T15? "supposed" to be a better trans for the 6 cylinder ?
sorry, I meant the AX15
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #33 of 45 Old 04-30-2013, 01:34 PM
Stormpaw
1983 CJ7
Bah, I just realized I did the same thing.
(Fixed previous post.)
post #34 of 45 Old 04-30-2013, 07:14 PM Thread Starter
DropeTine99
1981 CJ7
Thanks for all the info! Just to clear things up I'm not just looking for better mpg but the main thing is to lower my Rs so I don't tear my engine up. I just got these gears in so I'm not regearing. I go rock crawling a lot but I go on the highway a lot too. What would be the best transmission for lowering my Rs? I'm going to tune everything and get some headers.
Don't hit kids, no seriously they have guns now.
Looking for rebuilt T-5 transmission.
DropeTine99 is offline
post #35 of 45 Old 04-30-2013, 07:44 PM
Stormpaw
1983 CJ7
Well, in that case you were on the right track, an overdrive would be the way to go. The AX15 and NV4500 are the best I can think of (someone else probably knows more) if you want a manual transmission. Both would give you an overdrive fifth gear. The AX15 would raise your low end slightly (still assuming you have an SR4), and the NV4500 would lower it considerably. I have no idea how much a swap for either would cost, but I am pretty sure the NV4500 are quite a bit more expensive.
post #36 of 45 Old 04-30-2013, 08:12 PM Thread Starter
DropeTine99
1981 CJ7
The AX15 would bolt in wouldnt it?
post #37 of 45 Old 04-30-2013, 08:29 PM
jeepwhore
You need a conversion pilot bushing, a clocking ring for the t case, modify the drive shafts and convert to a hydraulic clutch. But yes, the bell housing will bolt up to a 4.2L
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #38 of 45 Old 04-30-2013, 08:35 PM
Stormpaw
1983 CJ7
Apparently, the front bearing retainer has to be changed on the earlier models to fit the 258, but the later ones should bolt right up. You would, however, need an adapter to mount the Dana300 to the AX15.
I hope that helps.
post #39 of 45 Old 04-30-2013, 08:37 PM
CSP
Originally Posted by DropeTine99 View Post
My tach stopped working but I top out somewhere around 60 mph, I'm guessing 2900-2800 rpms lol I went from a 2.73 R&P to the 4.10s and lost like 10 mph and some mpg. I don't get it lol Only thing I could think of was the tranny.
If you're truly doing 60mph and have tires that are actually 33" (most aren't) you should be turning around 2500 rpms at 60mph with the four speed (1:1 ratio in fourth).
Plug your info into this calculator.
www.grimmjeeper.com/gears.html
CSP is offline
post #40 of 45 Old 04-30-2013, 09:04 PM Thread Starter
DropeTine99
1981 CJ7
None if my gauges are working -_- how much of a difference would just getting headers, electronic ignition and get a better carb make? Think it'd lower my Rs by at least 200? And I can't use that calculator without my speedometer working can I? Ill start looking for a AX15!
post #41 of 45 Old 04-30-2013, 09:41 PM
titomars
1981 CJ7
Any engine tuning or mods IE: headers, will not change how fast the engine turns at a given speed. That is purely mechanical dependent on final drive ratio, tire size and transmission output ratio. All three of those upgrades will get your engine RPM's up faster and depending on other factors raise your top RPM.
If you really plan to seriously rock crawl, an AX15 is probably not the best choice either. The NV4500 is the best choice for strength with an O/D
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #42 of 45 Old 05-01-2013, 11:02 AM
Stormpaw
1983 CJ7
Oh, that is a nice one CSP.
Yes, you can. It is similar to the Novak gearing calculator I mentioned earlier. Just enter your transmission, t-case, axle gears, and tire size and it will tell your RPM at a given speed, speed at a given RPM and crawl speed at a given RPM. Although, that last one seems to be off (probably just needs to be divided by 100.) It also lets you compare your current set up side-by-side with the setup you are considering.
With a manual transmission, speed at a given RPM will always be the same for a given set of gears and tires unless:
1. Your clutch is slipping.
2. You wheels are slipping.
3. Your drive train is tearing itself apart.
However, getting your gauges working might be a good first step whatever you decide to do so you have real data on the performance of your engine to work from.
post #43 of 45 Old 05-01-2013, 06:45 PM Thread Starter
DropeTine99
1981 CJ7
Ill start looking for the transmission. Thanks fit clearing things up! What's the underdrive?
post #44 of 45 Old 05-01-2013, 08:07 PM
Stormpaw
1983 CJ7
Underdrives are an extra set of reduction gears that can be installed between the transmission and t-case (sort of like having a second t-case to drop into low.) An interesting device, but expensive and not very practical in short wheel base Jeeps.
If you are asking because of the calculator, just leave it on none.
post #45 of 45 Old 05-01-2013, 08:28 PM Thread Starter
DropeTine99
1981 CJ7
Thank you! Lol
cj7 , jeep , tranny , transmission
