CJ7 Transmission Problems - JeepForum.com
post #1 of 6 Old 09-04-2011, 03:05 PM Thread Starter
bigdog101
Hey guys,
My uncle has a 1985 CJ7, inline 6, 5 speed. Lately, the tranny pops out of 1st gear every time you use 1st, unless you hold it in. The other time its acted up was when he was cruising, he found that it would not come out of 3rd gear. When he finally got it out of 3rd, where the neutral position would normally be, was 1st gear.
Im sorry I don't know what kind of transmission it is right now. Any idea's?
Thanks!
Scott
bigdog101 is offline
post #2 of 6 Old 09-04-2011, 04:06 PM
agear
Its probably the factory borg warner T5. This it what it looks like
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 6 Old 09-04-2011, 04:38 PM
agear
maybe it's something with the shifter or linkages.
agear is offline
post #4 of 6 Old 09-04-2011, 04:50 PM
agear
If you take off your tunnel cover you'll see this if you manage to get all the bolts off of the cover, the one in the back is a big challenge , But I got it with a universal joint , and socket and ratchet. then you'll see that part with the holes and grooves for the tab and spring and detent ball.
maybe it's something with the shifter or linkages and I also saw a post , where someone said on the little plastic tabs that goes on the shift forks fell off and he was having a problem like yours
agear is offline
post #5 of 6 Old 09-07-2011, 05:28 AM Thread Starter
bigdog101
SWeet, thanks man. I have to talk to him to see what he wants to do with the tranny at this point.
post #6 of 6 Old 09-07-2011, 12:55 PM
agear
your welcome !
agear is offline
Transmission problems help rak09 Jeep CJ Forum 3 09-16-2012 06:51 AM
Transmission Problems michanecash Jeep CJ Forum 21 03-08-2010 01:55 PM
CJ7 Transmission Problems CJScout Jeep CJ Forum 6 11-18-2008 03:59 PM
Transmission Problems jeep72cj5 Jeep CJ Forum 5 10-30-2006 05:07 AM
Transmission problems Builder1 Jeep CJ Forum 4 08-19-2001 07:30 PM
