CJ7 trans and t-case swap - JeepForum.com
post #1 of 2 Old 11-02-2009, 03:25 AM Thread Starter
joker3266
just got a 77 CJ7 that im currently building. It has the 304 with the TH400 trans and quadratech t-case in it. I have a set of built rears with gears and lockers I had on my bronco. I'm looking for a transmission/t-case combo that will put the front out put shaft on the drivers side. Was thinking about using a t-18 trans with hopefully some kind of ford adaptable t-case.
joker3266 is offline
post #2 of 2 Old 11-02-2009, 08:52 AM
rustymudder
1982 CJ7
If you want heavy duty, then go with the ford t18 and whatever factory hd tcase comes behind it, probably the 208. Another option is lighter duty. get a AX-15 and a NP231 from a wrangler.
I have a ford t18 in my CJ7 and I love it. I would recommend going the heavy duty route.
rustymudder is offline
Trans to t-case seal Squatch Jeep CJ Forum 6 03-05-2009 12:33 PM
trans t-case swap XJ to CJ atomicflatulenc Jeep CJ Forum 2 12-02-2008 08:46 AM
T-Case/Trans & clutch are out... Need Help! Blue83CJ7 Jeep CJ Forum 3 11-01-2008 09:59 PM
trans case? smitch Jeep CJ Forum 5 06-28-2006 04:31 PM
cj trans case 85xj350 Jeep CJ Forum 0 09-25-2005 12:29 PM
