cj7 trans mount and torque arm - JeepForum.com
post #1 of 17 Old 02-04-2013, 08:41 PM Thread Starter
Vic99TJ
Ok so a buddy of mine has got a 85 CJ7 4.2 t4 trans. The trans mount can not be found locally. And as far as the torque arm... What bushings are you using? Or is it a possibility to remove the torque arm??
Thanks!!!
OnlyAjeep
Vic99TJ is offline
post #2 of 17 Old 02-04-2013, 09:50 PM
CSP
The torque arm bushing is usually available at the same places you find the trans mount bushing at. Do not remove the torque arm! It definitely serves a purpose.
CSP is offline
post #3 of 17 Old 02-04-2013, 10:26 PM
walkerhoundvm
1981 CJ8
Torque arm bushings: eBay torque arm bushings
Trans mount: eBay tranny mount
walkerhoundvm is offline
post #4 of 17 Old 02-04-2013, 10:37 PM
caseypotts
1980 CJ7
You can do better on the price for the trans mount. I think I paid $5.00 for mine (little less). Take it to a real part store...one that understands how to use a book not just the computers and have them find the correct mount. I can find you my part number tomorrow if you need it.
And yes you need the arm.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #5 of 17 Old 02-04-2013, 11:50 PM
74Maverick
Where do CJs have torque arms at? Ive had 3 76-79-84 and Ive never seen one. Kinda curious.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #6 of 17 Old 02-05-2013, 12:06 AM
BagusJeep
1981 CJ7
No 14, bracket. It is above the gearbox crossmember so you need to get low and dirty to find it.
It is actually just an arm on the mount that you can get a bit more leverage on and it is mounted on some rubber bushings. It allows the gearbox / engine configuration to tilt sideways a bit, otherwise the gear shift would go all over the place.
No 3 and 17 are the nitrile rubber mounts which allow movement and insulate the frame to an extent, but it is the arm and its bushings that limit the movement.
If you have a CJ with a flapping about gear stick it is probably this gearbox mount and/or torque arm that is missing or perished.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 17 Old 02-05-2013, 12:12 AM
74Maverick
OHH When I heard torque arm I thought suspension and then I had a picture of a big suspension piece somewhere on the transmission going to a frame rail or some crazy thing.
Thanks
post #8 of 17 Old 02-05-2013, 12:15 AM
74Maverick
I still cant beleive you live in indo!! Surf much? I lived in maui for a bit and had a good buddy Ikin who was from indo. Well Enjoy.
post #9 of 17 Old 02-05-2013, 05:14 AM Thread Starter
Vic99TJ
Awesome thanks for the info!!!!
OnlyAjeep
Vic99TJ is offline
post #10 of 17 Old 02-05-2013, 07:25 AM
walkerhoundvm
1981 CJ8
Agreed 100%. Those were the first two I found to use as an example. You can get OEM rubber that'll last you another 20-30yrs, or the poly which will last longer than your jeep.
post #11 of 17 Old 02-05-2013, 09:25 AM
caseypotts
1980 CJ7
I see Morris4x4 has them for $11. They also have the bushings for the arm but I clicked off before I saw the price. Same one I have except I paid half that much.
Her Ride
post #12 of 17 Old 02-05-2013, 10:16 AM
caseypotts
1980 CJ7
MFR-PART NUMBER. ACR-2268.
I paid $3.41 for it last month.
Her Ride
post #13 of 17 Old 02-05-2013, 01:53 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
I replaced my motor mounts with Bombproof mounts from MORE. Then got rid of the torque arm completely and bolted the transmission mount to the skid plate (like it is on almost every other vehicle made).. I have wheeled the heck out of it and had no problems. It is quiet (no thunking) and the LOKAR shifter doesn't move an inch even in the most extreme angles. I lost a stock motor mount on a trip once going up Signal Pk. I tried to return as easily as I could, however the other mount gave going down the mountain and all hell broke loose. The torque arm bent like a popsicle stick and sent my 258 right through my radiator. After a heck of a time getting the CJ off the trail and home, I modified the skidplate to accept a poly trans mount, installed the BP motormounts and went back to Signal pk. Have been up it 10 times since then with no issue.
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #14 of 17 Old 02-05-2013, 02:11 PM
walkerhoundvm
1981 CJ8
Pics or it didn't happen.
post #15 of 17 Old 02-05-2013, 02:49 PM
hasselback
You can build your own torque are real easy. Just get a 2 inch wide C channel, or 3/16 steel. Get a trans mount bushing like what I have on the right, and on the left, I have a shackle bushing above and below the arm with a 1/2 inch bolt through the center. Don't go exactly by my pic, because I had the trans mount too far to the right. The left bolt hole on the mount goes to the center hole on the trans.
hasselback is offline
