CJ7 Tierod replacement, how hard is it to do? - JeepForum.com
post #1 of 2 Old 02-28-2010, 07:33 AM Thread Starter
TWMCJ7
1976 CJ7
How hard is it to replace a stock tie rod end on a 76 CJ 7? I figure itís bad since I can grab the long tube in my hand and twist the tube and it moves, I see a movement in the driver side tierod, and this is while itís sitting on the ground not jacked up. Any detailed instructions would be nice.
Thanks
TWMCJ7 is offline
post #2 of 2 Old 02-28-2010, 07:53 AM
Mike Romain
The tie rod should move, I just put a new drag link in with removable ends like a tie rod and it was a pain to line up both ends square with the parts. The tube will move by hand now and it is new. However, it is tight, not loose.
I loosen off the castle nut to the end of the threads, then hit it hard with a hammer and it usually pops out. I have just hit the bolt before, but that can cause it to bend or mushroom before it pops out so I like to leave the nut on a bit. I live in the rust belt however and have had far too many castle nuts spin out and not loosen off so I had to cut the suckers off.
You can measure the length of the rod now to get it close when you reinstall it. If the makes of the tie rod ends are the same (ya right), then you can get it pretty exact this way. One thread turn in or out is a big measurement and if you leave the other side attached, you might be exact.
If not, you have to loosen off the other end's lock nut only and the stabilizer shock so you can spin the tube to do the alignment. Lots of good penetrating oil is called for and a pipe wrench may even come in handy for turning the rod but be careful, a pipe wrench can crush. I use vise grips also for grabbing the rod, they can slip and are less prone to crushing. Though if it is that freaking tight, more penetrating oil is called for.
Then you can do the alignment right in your driveway. I use the seam of the tire as a measuring point and measure across the front of the tires as high up as I can and then across the back of the two tires. The front measurement should be about 3/16" less with 33" tires. A little less with smaller tires.
I have been using this method since 97 on this CJ with perfect tire wear.
Mike
Mike Romain is offline
dana 60 axle shafts hard to turn after replacement mowjoecj Jeep CJ Forum 0 12-14-2009 04:56 PM
Replacement Glass for CJ7 Hard Doors Fjguercio Jeep CJ Forum 7 12-19-2008 08:01 AM
Replacement Hard Doors kanute Jeep CJ Forum 3 09-08-2008 01:47 PM
Tierod flip CJ51973 Jeep CJ Forum 4 10-05-2004 03:06 PM
Hard Door Handle replacement... 2JeepOrNot2Jeep Jeep CJ Forum 9 03-03-2004 11:32 AM
