CJ7 Temp and Fuel sensor Problems - JeepForum.com
post #1 of 2 Old 08-29-2011, 06:34 PM Thread Starter
DOWNING91
1979 CJ7
Ok, So I've only had this CJ7 for a month, when I got it there was no floor pan in the rear, so I had a clear shot at the gas tank. The fuel tank sender was hooked up correctly and apparently working correctly also. So I decided to install a new speedometer cluster with fuel and temp gagues. Once I had it in it seemed fine for two weeks. Then, and I'm not sure if they're related or not, I flushed and refilled the coolant and changed the thermostat, in that I had to disconnect the sensor for the coolant temp while changing the thermostat. I hooked it all back up and everything was working right. Then a day later I went to move the CJ from one side of the parking lot to the other and now both the Fuel and Temp sensors are reading at maximum. I climbed up under the dash, everything is connected, as well as the temp sensor on the engine. I noticed the hold down nut on the fuel gague (the jumped grounding nut) was loose, i tightened it and the gague went to zero. So the problem is that its either reading full or at zero on both gagues even when the engine is cool and I know theres 3/8 a tank of gas. Since these are new gagues I doubt its them, also they worked yesterday Is this a grounding issue? I'm new to jeeps so any help would be great.
DOWNING91 is offline
post #2 of 2 Old 08-30-2011, 03:09 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Grounding is a big issue. IF you loose your ground ou can burn out your gauges or sensors. Look in my sig to learn how to test them.
John Strenk is online now
Fuel?Temp sensor question dadsdream85 Jeep CJ Forum 6 07-22-2011 03:38 PM
sensor problems (temp, volt, reverse) jeephammer? Matt_G Jeep CJ Forum 4 06-24-2011 06:24 AM
Please Help Temp & Fuel Gauge problems RKC1801 Jeep CJ Forum 2 04-04-2010 08:05 PM
Radio/Blinker/Fuel/Temp Gauge Problems hieber22 Jeep CJ Forum 4 09-24-2009 04:06 PM
Temp sensor bdeck Jeep CJ Forum 1 07-10-2008 05:24 PM
