CJ7 Tach elimination - JeepForum.com
post #1 of 5 Old 03-17-2014, 02:53 PM Thread Starter
JeepCJ71985
How do I eliminate the stock (1985 CJ7 258) tach? I recently purchased a set of aftermarket stepper motor speedo and tach: wish to eliminate the stock one, realizing that it is part of the ignition circuit, the Jeep will not run without it (so I have it tucked under the dash LOL).
JeepCJ71985 is offline
post #2 of 5 Old 03-17-2014, 03:17 PM
SLO_Ken
Unplug the stock tach from the harness under the dash. Plug the two harness side connectors to each-other. Done.
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline
post #3 of 5 Old 03-17-2014, 04:18 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
As usual, Ken is spot on.
Here's the pic that should help. Just plug the two connectors labeled "Tach Plug" together.
Matt
Matt1981CJ7 is offline
post #4 of 5 Old 03-18-2014, 11:46 PM Thread Starter
JeepCJ71985
I'll give it a shot! Thanks! I will post some pics when I'm done with the Jeep. Its going to be painted soon, then I can reassemble everything.
post #5 of 5 Old 03-19-2014, 06:25 PM Thread Starter
JeepCJ71985
Thank you Ken and Matt, it worked out perfectly.
