CJ7 stock rear draw/tow bar removal - JeepForum.com
post #1 of 9 Old 06-06-2014, 11:16 PM Thread Starter
hicks1983
Hello everyone. I am stripping down my jeep for a restoration and am stuck on removing the rear drawbar mounted to the rear frame/bumper under the spare tire carrier. The bolts I assume have nuts on them but the access is zero to get a wrench on them. How do you remove these bolts??? Thanks
hicks1983 is offline
post #2 of 9 Old 06-06-2014, 11:22 PM
LumpyGrits
Drop the gas tank.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 9 Old 06-06-2014, 11:31 PM Thread Starter
hicks1983
Not worth the work if that's the only way. I guess the draw bar stays
post #4 of 9 Old 06-06-2014, 11:37 PM
LumpyGrits
That's your call.
You did say 'restoration', so that shouldn't be an issue since most real restorations include pull'n the gas tank for inspection and such. As in repair/painting the frame etc.
BTW-You have a '20' in the rear. Not a 30, as you indicate in your profile
LG
post #5 of 9 Old 06-06-2014, 11:56 PM Thread Starter
hicks1983
Typo
post #6 of 9 Old 06-07-2014, 12:17 AM
only in a jeep cj
Hell, sometimes I remove the entire body to have access to the frame and room to work. The gas tank is a few hoses and 8 bolts......
Any resto will involve removing most or all the major parts.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #7 of 9 Old 06-07-2014, 06:25 AM
keith460
Jeep. There's Only One
keith460's Avatar
You shouldn't have to drop the fuel tank to take off an accessory. My 84 had a Draw Bar and I could put it on or take it off as needed with regular hand tools.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 9 Old 06-07-2014, 08:26 AM
Mike Romain
The stock one on my 86 bolts on from the back, not the bottom and the nuts are under the gas tank skid plate. Have the 20 gallon box skid, no access.
Mike
Mike Romain is offline
post #9 of 9 Old 06-07-2014, 10:18 AM
LumpyGrits
Same here.
LG
