CJ7 stock height... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ7 stock height...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREELifetime LED on Sale at Baseline 4x4 Outfitters LED Light
Unread 04-28-2007, 10:14 AM   #1
vladrulli
CJ7 stock height...
Can anyone tell me how high the frame is from the ground on a stock cj7?
Installed a 2.5" lift-kit... the shocks that came with the kit appear to be too short... now I'm not sure if I just got the wrong shocks or the wrong springs(that is 4" lift-kit)...
vladrulli is offline   Reply With Quote
Unread 04-28-2007, 12:22 PM   #2
Rob55
I can't tell you what the stock length shock is, but the frame to ground measurement can vary by age/use/tire size. Any of the shock manufacturers can tell you the factory length (fully extended and compressed), so can most lift manufacturers. I'd check with their tech support first and see what they say.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline   Reply With Quote
Unread 12-03-2008, 06:04 AM   #3
shank38242
Thought I would bring this one back up to see if anyone has, or could get a close measurement from frame rail to ground of a stock, or very near stock CJ7?
Thanks,
Steve
shank38242 is offline   Reply With Quote
Unread 12-06-2008, 01:04 AM   #4
mattcj7258
1983 CJ7
my 83 CJ7 measures 14 3/4 at the front of the T case skid plate. The only non stock suspension is the tires--slightly taller than stock....although the leaf springs are pretty much flat now.....so i'm pretty sure its damn close
mattcj7258 is offline   Reply With Quote
