CJ7 Steering Upgrade - JeepForum.com
post #1 of 5 Old 04-26-2010, 07:06 AM Thread Starter
kdgraben
1979 CJ7
What is the best steering system upgrade for a heavily modified CJ7? I am running massive 35" TSL/SX tires and 8" lift. My power steering box is stock now and I get a random steering wobble in the front end.
Thx,
Karl
kdgraben is offline
post #2 of 5 Old 04-26-2010, 07:15 AM
Jim1611
Jim1611's Avatar
I haven't used one but I see some of the rock crawler guys adding a hydraulic assist to their steering system. Also the ARG boxes seem to work very well and sound like they would be more streetable if you need that.
Something else that may be causing you problems is 8" of lift. Do you have a dropped pitman arm? What axle are you running? If you haven't done it yet you need to have the tie rods flipped on top of the steering knucles, that would reduce the angle of the drag link. You may be getting allot of bump steer with that much lift.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 5 Old 04-26-2010, 07:43 AM Thread Starter
kdgraben
1979 CJ7
Jim, I do have the dropped pitman arm and I have flipped the tie rods. I am running the wider axles from an '86 CJ7.
Have you heard of the stock steering box getting sloppy over time?
Thx,
Karl
kdgraben is offline
post #4 of 5 Old 04-26-2010, 10:39 AM
78treehugger
1980 CJ7
Yes they can get sloppy overtime. I swapped mine for a J20 gear box and have been very happy. I run 35"s and am mostly trails but I only have 4" total lift. I did the tie rod flip also. Check your gear box bracket. If you haven't purchased a heavy duty mount then I'd suggest that as well as a brace. These really helped tightening my steering. Also check your tie rod ends.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #5 of 5 Old 04-26-2010, 10:51 AM
Jim1611
Jim1611's Avatar
Yes your stock steering box is going to wear. I would install these. TELLICO4x4.com has them.
I would use the M.O.R.E. steering box mount SB7686Z
ARG steering box AGR-262357
ARG repalcement pump AGR-262357
Heavy duty steering box brace Omix-Ada 18021.02
Oversize tires are going to put allot of stress on your steering components and wear will occur at a faster rate. These parts are made better than factory, there are others available too.
My build thread
Jim1611 is offline
1979 , cj7 , steering , upgrade
help with power steering upgrade tony dz Jeep CJ Forum 13 07-07-2009 11:56 AM
CJ7 Steering box upgrade CJ7RHD Jeep CJ Forum 6 06-25-2009 05:44 PM
Need a steering box upgrade CJ Chet Jeep CJ Forum 1 12-23-2008 08:27 AM
73 cj5 steering upgrade fl-jeep Jeep CJ Forum 4 09-20-2007 08:49 PM
Steering upgrade for '85 CJ7? medunwoody Jeep CJ Forum 3 07-02-2006 03:28 PM
