CJ7 Steering question. - JeepForum.com
post #1 of 12 Old 07-09-2011, 10:25 PM Thread Starter
DrDenz
Hi All
I am currently rebuilding my CJ7 81. I want to improve the driveability and handling of the CJ even at high speeds. Can anyone suggest what gearbox steer and other steering components to use? I heard some used an XJ steering component to get better driveability and handling. Are there any other suggestion?
Thanks kindly...
DrDenz is offline
post #2 of 12 Old 07-10-2011, 04:38 AM
nshefbuch
1982 CJ7
Originally Posted by DrDenz
Hi All
Thanks kindly...
I haven't done this but check into a Durango steering box. What I did is replace mine with a stock one from o'riellys and it helped out alot.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #3 of 12 Old 07-10-2011, 04:56 AM
gojeepin
1983 CJ7
The CJ steering equipment handles fine at high speed. If you're having handling problems it may be broken, worn out, or improperly adjusted.
What kind of problem do you have?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 12 Old 07-10-2011, 06:14 AM
243
1978 FSJ Cherokee
Originally Posted by DrDenz View Post
Hi All
Thanks kindly...
It will help tremendously if you will post a picture or two of you CJ along with the details of the current condition like tire size and type, shocks, brakes, steering components (recently replaced or c1981).
Dave's 78 Build
243 is offline
post #5 of 12 Old 07-10-2011, 06:22 AM
hp_lovecraft
1981 CJ5
My '81 was dangerous at high speeds. So I lifted the front end and discovered both wheels had severe wobble. Both at the bearings and tierods. Replaced those....(fairly cheap and easy). and now it drives straight as an arrow.. well, unless I hit a bump.
Is wandering the problem? or body roll? I also installed some add-a-leafs to fix up the body roll... and true enough, it has virtually none now, but its now very difficult to drive on dirt roads... so, a decent lift is in my future.
hp_lovecraft is offline
post #6 of 12 Old 07-10-2011, 07:54 AM Thread Starter
DrDenz
Yes my existing steering control is broken. I just wanted to find the best option before buying the stock steering box. I was also considering on adding a tough dog steering shock, is this a good option? I use my CJ7 mainly on road with the occasional off roadin but not hardcore.
DrDenz is offline
post #7 of 12 Old 07-10-2011, 08:06 AM
gojeepin
1983 CJ7
The stock steering equipment is fine and doesn't require modification to reinstall replacements.
If your steering geometry is set properly, you won't need a steering damper (shock) unless all your roads are very rough. I looked for this on the Tough Dog site but they don't have CJs listed and I couldn't find a steering damper but usually these kits are all about the same.
gojeepin is offline
post #8 of 12 Old 07-10-2011, 08:32 AM Thread Starter
DrDenz
I found the Tough Dog damper at http://www.4waysuspension.com.au/products. The specific product that i m considering is http://www.4waysuspension.com.au/pro...ng-stabilisers. It was a recommendation from a friend. But again i wanted to know whether it will bring added value.
DrDenz is offline
post #9 of 12 Old 07-10-2011, 10:01 AM
ymurf
1979 CJ7
Curious about this product to.Anyone here have one of them on there jeep?
ymurf is offline
post #10 of 12 Old 07-10-2011, 10:12 AM
gojeepin
1983 CJ7
I have a couple of thoughts on the Tough Dog damper.
1) few dampers in the US have a spring on them--they're to damp unwanted steering input not return to center.
2) the damper/spring assembly, if mounted properly can assist return-to-center, if not it will cause the steering to pull one way or the other.
3) Properly aligned steering doesn't need a steering damper... I run 35X1250s without one.
Does your Jeep wander? You need to determine if it's due to broken, loose, or worn out parts... if not it's probably your caster setting.
gojeepin is offline
post #11 of 12 Old 07-10-2011, 10:24 AM
L78THUMPER
2007 MK Compass
If you THINK you need a damper theres a problem with you steering and a damper will just cover it up!!!!!!!!
FIND out what the problem is and fix that don't cover it up
L78THUMPER is offline
post #12 of 12 Old 07-10-2011, 11:01 AM
brownbagg
1930 MK Compass
it also depend on tire size and road conditions, a lot of interstate has grooves from the big rigs, if your large size tire, light weight vehicle hit those groove it will make the vehicle wander
brownbagg is offline
cj7 , cj7 rebuild question , steering
CJ7 Steering Question?? 82silverbullet Jeep CJ Forum 7 06-14-2011 05:15 AM
Another Steering Question tcl632 Jeep CJ Forum 8 07-05-2010 01:35 PM
Another steering Question... Blue83CJ7 Jeep CJ Forum 2 09-29-2006 03:41 AM
CJ7 Steering question kingerjeep Jeep CJ Forum 1 02-06-2006 06:18 PM
Steering question benny6 Jeep CJ Forum 3 06-11-2002 09:12 AM
