CJ7 Steering Question?? - JeepForum.com
post #1 of 8 Old 06-10-2011, 12:15 PM Thread Starter
82silverbullet
1982 CJ7
My 82 CJ7 steers almost twice has deep to the right as it does to the left. Is this normal or am I missing something obvious. It doesn't appear that anything is making contact???
82silverbullet is offline
post #2 of 8 Old 06-10-2011, 12:22 PM
CSP
Did you lift it and not adjust the draglink to make up for the additional distance between the passenger knuckle and pitman arm?
CSP is offline
post #3 of 8 Old 06-10-2011, 12:30 PM
lucdog
1980 CJ5
Nope, not normal.
Has it always been like this?
What CSP said, and the limiting bolt on the knuckel, drivers side.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 8 Old 06-12-2011, 01:39 PM Thread Starter
82silverbullet
1982 CJ7
The jeep has been lifted but before I bought it. It has steered like this since I've had it. How exactly do you adjust the draglink? I'm pretty sure the limiting bolt is not interfering with the steering.
post #5 of 8 Old 06-12-2011, 03:27 PM
Dngrs1
1979 CJ7
When the tires are pointing straight, check to see where the pitman arm is. If it is off to one side of center, there is the problem.
Dngrs1 is offline
post #6 of 8 Old 06-12-2011, 04:55 PM
lucdog
1980 CJ5
Post a couple pictures of the front axle steering setup. Are you sure the front is a Dana30?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #7 of 8 Old 06-13-2011, 02:13 AM
43Duc
1982 CJ8
This post inspired me to adjust my steering wheel to be straight. After further inspection I found that my steering was hampered in the right turn vs. left as the OP stated. However, mine was not hitting the stops. I dropped the pitman arm and found that my steering was being limited to the right by the steering gearbox's internal stops. I guess I wasn't paying attention when I installed the gearbox and didn't line it up right. Once I centered the steering grearbox and made a small adjustment at the adj. tube I was good to go. Thanks for the inspiration!
43Duc is offline
post #8 of 8 Old 06-14-2011, 06:15 AM Thread Starter
82silverbullet
1982 CJ7
The front axle is a dana 30. I'll try this evening to check the pitman arm and gearbox.
steering set up question SOA billybooster2 Jeep CJ Forum 4 01-02-2011 07:27 PM
steering box question roscoe72003 Jeep CJ Forum 2 10-06-2010 03:53 AM
Another Steering Question tcl632 Jeep CJ Forum 8 07-05-2010 02:35 PM
Another steering Question... Blue83CJ7 Jeep CJ Forum 2 09-29-2006 04:41 AM
Steering question benny6 Jeep CJ Forum 3 06-11-2002 10:12 AM
