cj7 stalling problems - JeepForum.com
post #1 of 5 Old 02-08-2002, 04:15 PM Thread Starter
cj7paul
Post cj7 stalling problems
My 1985 CJ7 has a frustrating knack of stalling when it is idling at the lights. I think the problem is due to some component of the ridiculous emission control system that was built into this vehicle.
I have replaced the PCV valve system and many of the hoses in the engine compartment and all other vacuum hoses seem to be in the right place.
Many mechanics have looked at the jeep and all they can suggest is turning the idle speed up to a very high RPM (which frightens people at crossings).
Has anybody had a similar problem or can suggest a fix?
cj7paul is offline
post #2 of 5 Old 02-08-2002, 04:55 PM
ooze
Post
faulty EGR valve?
ooze is offline
post #3 of 5 Old 02-08-2002, 05:38 PM
Bob K
Bob K's Avatar
Post
Generaly this problem is caused by vacuum leaks. One common problem area is the throttle plate shaft where it goes through the throttle body. Test by wiggling it for up and down or fron to rear movement or spray starting fluid at that area and see if your idle speed increases indicating a vacuum leak there. Have you tried the idle tube modification? It is described on the YJ board by BillyBadAss. It's a simple mod and allows the carb to compensate for lean running conditions. Try this link for the idle tube mod.:
http://www.jeepforum.com/cgi/ultimat...&f=14&t=000183
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #4 of 5 Old 02-08-2002, 09:58 PM
bluebogger
Post
Bob K. had a very good reply, don't forget to check the choke operation and overall carb conditions. My CJ-5 had the same problem.
bluebogger is offline
post #5 of 5 Old 02-08-2002, 09:58 PM
bluebogger
Post
83 CJ7 with EFI stalling hbl21 Jeep CJ Forum 4 10-08-2009 03:26 PM
Stalling -> Hesitation -> Stalling 77cj52009 Jeep CJ Forum 11 07-29-2009 05:41 AM
Stalling out? bodge Jeep CJ Forum 2 05-04-2008 07:21 PM
Stalling..... dali555 Jeep CJ Forum 1 05-11-2005 06:29 AM
downhill stalling problems redlinedcj Jeep CJ Forum 5 04-22-2005 02:16 PM
