cj7 speedometer cable - JeepForum.com
post #1 of 18 Old 08-29-2011, 12:00 PM Thread Starter
lastseen
Having a dickens of a time getting speedometer cable to work on my 86 cj7.
I'm on cable number three. I take it you have to cut the cable to get it to fit.
Or am I looking at it wrong? Purchased cables through 4WD.com
lastseen is offline
post #2 of 18 Old 08-29-2011, 12:10 PM
Renegade82
1982 CJ7
Shouldn't have to cut anything. Both ends should have a fastener to screw onto it's termination point, ie: drive train and speedo. I have a new one setting at home that I'll have to look at.
Renegade82 is offline
post #3 of 18 Old 08-29-2011, 02:41 PM
LiveTo4x4
1977 CJ7
I recently installed a new cable, bought from Jeep4x4center and it had to be trimmed a little on both ends. If I remember it was alot from the transfer case end, 1/2" maybe and less on the speedometer side, maybe 1/4". just trim a little at a time.
'77 CJ7 Golden Eagle: Cummins 4BT, NV4500, NP205, Old Man Emu 2.5" YJ conversion lift, 3.31 stock NT axles (with 2" spacers), 32x10.5-r15 Good Year Wrangler Authority
LiveTo4x4 is offline
post #4 of 18 Old 08-29-2011, 06:07 PM
Renegade82
1982 CJ7
Oh, so your just talking about nipping a little bit off the squared end to be able to screw the nut on, I see. Did you compare it against the old one or was it too damaged or broke?
post #5 of 18 Old 08-29-2011, 06:21 PM
DOWNING91
1979 CJ7
I just changed mine yesterday on a 79 cj7. It wasn't too hard I got one from autozone for $9. It already had the threaded ends on it and screwed right on. It actually took a couple tries to get it on just because I didn't have it at the right angle. I don't think you should have to trim anything though, just keep rotating it until it fits in right.
DOWNING91 is offline
post #6 of 18 Old 08-29-2011, 06:55 PM Thread Starter
lastseen
The old one had a chewed up end. Bought a cable from local parts store today. It looks to be proper length without having to trim. Will install it in a few days. Thanks for the entry.
lastseen is offline
post #7 of 18 Old 08-29-2011, 07:52 PM
LiveTo4x4
1977 CJ7
i ordered mine, and with the way these online Jeep parts dealers are these days, I probably didn't get the right one for the job! i did trim a little at a time until it fit right and I could screw the ferrel/nut onto the xfer case/speedo.. I couldn't use the old one because it sheered off at the speedo for some reason.. 34 years old I guess..
post #8 of 18 Old 08-29-2011, 08:27 PM
OldSkull
1980 CJ7
Are you talking about a replacement cable only or the housing along with it?
304 - T176 - D300 - D30 - M20 - 4" Superlift - 35-13.5x15 Krawler T/A's - TJ Flares - Team Rush - MSD 6A - Cavalier Seats
OldSkull is offline
post #9 of 18 Old 08-29-2011, 08:35 PM Thread Starter
lastseen
I think I've got the right cable now. Will install in a few days.
lastseen is offline
post #10 of 18 Old 08-29-2011, 08:44 PM
OldSkull
1980 CJ7
What was the problem? Post the solution when you can; I see a ton of threads asking for help and never post the problem/solution. I'm sure it will help the next guy when he/she does a search.
OldSkull is offline
post #11 of 18 Old 08-30-2011, 12:56 AM
eastin82
1981 CJ5
wonder if the speedo gear turned and isnt making contact n e more?
eastin82 is offline
post #12 of 18 Old 08-30-2011, 10:48 AM
chevyman31ron
1978 CJ7
I thought my cable went bad, got a new one. Still didn't work. Thought it had to be the speedo, got a new one (note; expensive and hard to find). Still didn't work. Turned out the plastic gear in the transfer case was stripped. Temporary solution, borrowed my girlfriend's GPS. Ended up finding a used transfer case for $40 and got my gear and other spare parts out of it.
chevyman31ron is offline
post #13 of 18 Old 08-30-2011, 10:51 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
Originally Posted by DOWNING91 View Post
...just keep rotating it until it fits in right.
thats what she said
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #14 of 18 Old 08-30-2011, 01:04 PM
Cutlass327
1978 CJ5
I had to trim off each end with the one I got from 4WDH also. I've tried the replacement cable insert, but the housing got damaged when it got caught on something when removing the tub when I did my frame swap.
My issue I'm having now, 3 cables later, is that the speedo jumps around. Every time I disconnect it, move it underneath, whatever, it bounces about 10 MPH until I get to a certain speed. It's almost like the cable is binding, but there are no kinks, sharp turns, etc in it. I've tried a couple different lubes, but no better. Any of you changing your cables having this issue?
Rick
Cutlass327 is offline
post #15 of 18 Old 09-07-2011, 10:27 AM Thread Starter
lastseen
Had the same problem with two cables. The third one worked. Make sure you have the speedo end secured
tightly or the cable will wobble inside the sheath. That's my theory anyway. Good luck.
lastseen is offline
Speedometer cable location??? rocks4x4 Jeep CJ Forum 3 12-10-2010 03:23 PM
Speedometer cable manderson2228 Jeep CJ Forum 3 10-27-2009 08:19 AM
Speedometer Cable For T-18 mud4me Jeep CJ Forum 2 03-18-2006 05:00 PM
speedometer cable? duc dowg Jeep CJ Forum 2 12-23-2005 03:18 PM
Speedometer Cable on '57 CJ5 billy79 Jeep CJ Forum 8 09-30-2005 05:04 AM
