CJ7 slack in the rear diff - JeepForum.com
post #1 of 2 Old 03-30-2010, 02:05 AM Thread Starter
rex_altitudo
I'd like some advice on diagnosing slack in the rear differential of my 1985 CJ7 with the stock AMC 20 and 2.73 gearing. When moving through the gears, the driveline very noticeably clunks as the torque on it changes. When parked, I can grasp the rear driveshaft and turn it; there is about an inch of play. I was wondering if anybody could guess what was worn out (ring/pinion, differential, axles...). There is a locker in the rear and one-piece axles, but I don't know any details on these mods as they were done by previous owners.
rex_altitudo is offline
post #2 of 2 Old 03-30-2010, 04:38 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The ring and pinion may be worn a bit, but you are describing the normal behavior of a locker. Practice your shifting or remove the locker. Double check that the u-joints are not worn out.
CJ7-Tim is offline
amc 20 , differential , rear differential , rear end , rearend
13 degrees slack in timing chain Old4X Jeep CJ Forum 17 02-24-2009 07:32 PM
New CJ-7 Owner. SHIFT LEVER SLACK?!? Hondaluvr1985 Jeep CJ Forum 8 11-16-2008 08:17 PM
Rear Diff Angle/Rear driveshaft w/pic DuggerCJ Jeep CJ Forum 12 12-17-2007 06:43 AM
Slack Steering 77 Cj-5 boydog40 Jeep CJ Forum 1 02-06-2006 09:46 AM
Rear Diff jeepsarecool Jeep CJ Forum 22 02-03-2005 10:55 PM
