CJ7 running oddly - Page 2 - JeepForum.com
post #16 of 23 Old 06-01-2012, 06:34 AM
jeepwhore
Maybe the power valve in the carb? If it loaded up and backfired it could have blown out the power valve. Not sure if it will cause the same symptoms but it's something that's easy to check and replace before you start tearing the engine apart.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #17 of 23 Old 06-01-2012, 12:14 PM
Mickey_Mouse
2013 KK Liberty
the cam is easily replaced, and done so infrequently. take off the timing cover and a freeze plug and you should be ready to roll!
Mickey_Mouse is offline
post #18 of 23 Old 06-01-2012, 12:44 PM
Dadamsnv
1977 CJ5
Was it a metal pop or a gas pop?? I had wacky stuff like that going on with mine when I bought it and it turns out a plug wire was bouncing of the exhaust manifold as the motor rocked on its mounts under load, which really screwed the spark up. It wasn't obvious until I looked hard at the wires.
Dadamsnv is offline
post #19 of 23 Old 06-01-2012, 05:34 PM Thread Starter
rtormet
more a metal pop - ill take a hard look at the plug wires just to be sure but i think they are OK
its very odd i think im going to replace the cam next
rtormet is offline
post #20 of 23 Old 06-01-2012, 06:21 PM
Mickey_Mouse
2013 KK Liberty
the distribtuor sits on top of the cam, if the gears on the cam look like they have had 'metal binding, deformed or twisted, the gears on the cam will look the same. I red-lined my tach, I was driving down the road when this happened, I was not stationary (got rid of the tach) and it killed the power to the distributor and ground my cam. Ended up replacing the whole distributor as well. If it seems like it wont crank over, metal to metal bindingthat could be the main cap bearing on your crank. you'll know when you take the motor apart b-c , the bearings that hold the pistons in, the bearings if you take them off, will appear shredded. or have deep cuts in their metal surface. and the motor will have a knocking sound, like a trash of metal hitting the block. thats one way to tell without have to take it apart.
post #21 of 23 Old 06-01-2012, 06:29 PM Thread Starter
rtormet
Ah gotcha - ill check that out tomorrow first thing and see how the gears look - seems like something thats pretty easy to check on
rtormet is offline
post #22 of 23 Old 06-01-2012, 06:35 PM
Mickey_Mouse
2013 KK Liberty
be sure to mark where you took the distribuotr out at , or you'll mess up the timing.
post #23 of 23 Old 06-01-2012, 06:36 PM Thread Starter
rtormet
Definitely - thanks
rtormet is offline
idle issue , motorcraft 2100 , rough idle
Transfer case shifting oddly...Gears in wrong position? cjthor Jeep CJ Forum 4 06-15-2010 05:02 PM
whats your 304 running temp? got air in my system...been running alittle hot. meatloaf Jeep CJ Forum 6 04-27-2009 04:57 PM
got her running scrappycj5 Jeep CJ Forum 6 01-12-2009 05:37 AM
Running Hot harlan Jeep CJ Forum 2 07-09-2007 03:24 PM
Which HEI are you running on your V-8? hfjeff Jeep CJ Forum 2 03-13-2006 04:58 AM
