CJ7 Rear Drum Brakes - Page 2 - JeepForum.com
post #16 of 23 Old 11-25-2011, 08:09 PM
Dborns
If you don't get any responses, try a search on here on "replacing drum brakes", or something like that. I've seen a bunch of pics that people have put on here when they are done with a brake job, or doing a rebuild. One thing to keep in mind, (next time), and a few people here mentioned it, is to only do one side at a time, and if possible take a picture before you tear into it. If you are working on one side and have the other open, you have an exact idea of what goes where. I've done all of my cars drums, and still use the other side for reference just to make sure I get everything back together correctly.
A Haynes or Chiltons manual will also show you what goes where, but the pics aren't that great.
Dborns is offline
post #17 of 23 Old 11-25-2011, 08:34 PM
DL_81_CJ7
I just swapped in a WT for my NT's and used the below thread for my rear drum reassembly. There is a picture from Coiz that is from an earlier CJ, but all the components are the same...
http://www.jeepforum.com/forum/f8/ea...e-help-813616/
81 CJ7 258
TFI
MC2100
DL_81_CJ7 is offline
post #18 of 23 Old 11-26-2011, 06:24 AM
foggybottombob
This is why you do one brake at a time.
foggybottombob is offline
post #19 of 23 Old 11-26-2011, 06:35 AM
Dborns
Yeah, not to keep saying that, but its exactly why. Theres no way you can ask "what goes where", and have anyone be able to tell you piece by piece. I'm going to be doing some work on mine today, and I'll try to figure out a way to get the picture from my Haynes manual onto here, but again its not that great of a picture. Check out Coizs' build thread; I'm pretty sure thats where I saw a great picture of the drum brakes on his. Its a long thread, but definately worth looking through anyway.
If you end up figuring it out, a couple tips on putting it back together- make sure and wear safety glasses because those springs can fly. Also, make sure and get the shoes on correctly; one is bigger than the other, and I believe that one goes on the back. Put high temp grease anywhere that metal touches metal on the backing plate, but DON'T GET IT ON THE SHOE.
I'll try to get that diagram scanned.
Good luck.
Dborns is offline
post #20 of 23 Old 11-26-2011, 06:44 AM
keith460
Jeep. There's Only One
keith460's Avatar
This photo may help. Its the drivers side rear.
1984 CJ-7 Renegade
keith460 is offline
post #21 of 23 Old 11-26-2011, 06:49 AM
CJ Chet
Sounds like you need this:
http://www.civilianjeep.info/84-86FSM/CJ-FSM-84to86.pdf
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #22 of 23 Old 11-26-2011, 10:18 AM
Coiz
1979 CJ7
Here is a picture of the passenger's side.
Mike
Coiz is offline
post #23 of 23 Old 11-26-2011, 12:18 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Like Dborns says, One mistake a lot of people make is putting on the wrong shoes in a set. There is a leading and trailing brake shoes on each side. One pad has more fiction material than the other. Look carefully at the photos above. The one with more friction material is on the back side and the one with less is on the side towards the front of the jeep.
John Strenk is online now
Rear Drum Brakes stansama Jeep CJ Forum 43 11-15-2012 08:27 AM
Question about disassembling rear drum brakes g_man500a Jeep CJ Forum 6 07-28-2009 03:24 AM
Rear Drum Brakes issue... CJmadison Jeep CJ Forum 4 02-23-2006 05:01 PM
Drum brakes, removing da' drum Blthomas Jeep CJ Forum 31 11-05-2005 05:04 PM
I need some help with my rear drum brakes 83cj-7 Jeep CJ Forum 2 09-11-2005 05:19 PM
