#1 | |
CJ7 Rear Drum Brakes
My 85 CJ7 is in need of rear drum brakes. Are these moderatly easy to replace? I have taken the rear wheels off and the drum for inspection. I feel fairly confident in my abilities, but don't want to get in over my head.
Thanks for your input!
#2 |
If you've taken them off before, half of your work is done,
Sometimes it takes longer to get the drums off than to do the rest of the job, just look at what is there, take a picture if need be, and put everything back as it was, just with the new parts, Pretty simple job really Good Luck !
Bill H. - 1984 CJ-7 258 W/ Weber DGV 32-36, T5, Twin Stick Dana 300, Custom SOA, Dana 30/AMC 20 Locked 4.56's, 33" Swamper LTB's, York OBA, Custom bumpers, Homemade Swaybar Disconnects, Nutter Bypass, Team Rush http://www.schohariecountyjeepclub.com |
#3 |
Is it necessary to bleed the brakes once completed. Someone told me it is not always needed. Is it possible to do the job without getting air in the line?
#4 |
I've replaced shoes several times and I'm a girl. A manual is your best friend for any repair in case you need help. Did you say you need new drums or are you just replacing shoes? Sounds like you are checking the drums before you reassemble, that will save you grief in the long run. You don't have to bleed the brakes if you don't open any line and let air in however, it never hurts to replace the old brake fluid and bleed the system if it hasn't been done for years. Adjusting the wheel cylinders to set the new shoes is done mechanically with a brake adjusting tool so unless you have suspicions about your hydraulic brake lines, don't open the bleed nipples on the cylinders and air won't enter. All in all, it's pretty easy.
#5 |
Running On Empty...
What has being a 'Gril' got to do with it?
I taught 'Women On Wheels' (WOW) classes for several years locally and may of them are doing their own maintenance to this day, and some of them became mechanics or do body work they liked it so well! Something very satisfying about working with your hands! If women knew how special a 'Hot Rod Chick' was in the 'Boys Club', there would be a LOT more 'Girls' taking auto shop!
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#6 |
Running On Empty...
Not 'Bleed' the brakes, but you might have to adjust them up once you get new drums.
DO NOT PUMP THE BRAKES WITH THE DRUMS OFF! You WILL pop a wheel cylinder open if you do! SO DON'T DO IT! There is an adjuster 'Star Wheel' at the bottom between the shoes, get familiar with it! Turn it one way, the shoes come together, Turn it the other way, the shoes get pushed out to meet the drum. With new drums, and especially new shoes and drums, you are going to have to move that thing 'In' to get everything 'New' to fit. Once the drum is on, you are going to have to turn that 'Star Wheel' 'Out' until the shoes are just 'Hazing' the drum, just barely rubbing the drum... If you look on the backing plate, you will find a slot (that should have a rubber plug in it!) for the adjuster tool... The adjuster workings and procedure is covered in your MANUAL pretty well... (you DID buy a MANUAL, Didn't you?...) Once the drum is on and adjusted up so you are getting just a little friction, Get in and hit the brakes to seat the shoes in the drum, (you don't need a wheel on for this, just do it with the wheels still off) Then check your adjustment again... Spin the drum and see if it's 'Hazing' slightly... Some times the shoes will become pretty loose in the drum once they seat in correctly, so you may have to adjust up a little... Not much to it once you figure out how the 'Adjuster' works and get it going the correct direction!
#7 |
jjustice08, who needs a manual when we have JeepHammer on board. Very good advice. Most of us learned the hard way not to push the pedal when the drums are off.
#8 |
Hey, at least if you accidentally do that you have an excuse to replace your wheel cylinders, which isn't a bad idea while you have that all apart anyways. You will certainly have to bleed the brakes if you replace the wheel cylinders though.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#9 |
I guess all this will make sense once I get the wheel off again. JeepMaster lost me with the "star" shaped wheel. Is this wheel adjacent to the adjusting lever?
The end result should be the shoes slightly touching the drum? Probably a good idea to take a "before" picture and see if it looks the same after completion. |
#10 |
check here for the adjuster-
http://auto.howstuffworks.com/drum-brake2.htm Don't forget to put plenty of never seize on that wheel, they like to rust up, and be a pain in the *** come adjustment time
#11 |
Another trick if your replacing brake shoes is to rebuild one side at a time. Don't pull both sides apart and then start your rebuild. That way you can look at the completed side and see if you have springs in right place and so on. Another thing is to have machine shop cut the drums to have them "in the round". They will resurface, "cut" the surface where the shoe rides so they are braking evenly.
#12 |
Here is a picture I posted on another forum related to my 1948 Chevy pickup. The adjusting theory is the same for the Jeep even if the cylinder looks a tad bit different. Clockwise on the adjusting star spreads the shoe toward the drum (tightens) Counterclockwise pulls the shoe away from the drum (loosens). Each cylinder has two adjusters, one for the forward shoe and one for the rearward shoe and that is when clockwise and counterclockwise gets confusing because you generally do final adjusting when the drum and wheel are bolted back on and you are now working from a picture in your head while you adjust.
![]() So you are adjusting through two little slots on the back of the brake flange plate. If you have a spring removal/installation tool it really helps. Brake tools are relatively cheap and you will use them again and again. A local library will have manuals you can check out. Really good advice from bigjoe, do one side at a time and use the assembled side as a reference. |
#13 |
Ok, great advice guys...thanks a bunch.
Now that yal have boosted my confidence level about tackeling this job myself, can you tell me some good brands of shoes and drums? What are some brands to stay away from....I don't mind spending the extra cash if it is better quality. |
#14 |
wrong posting
79BlackPearl 79 CJ7, 3" Lift, 360 V8, Edelbrock Performer Intake, Comp Cam, Holley 650 Truck Avenger, Hedman Headers, Moser Axles, Herculiner, Warn M8000i, 33" Timberlines Guaranteed to Make $$$$ with your Computer! No Risk Involved! Simply press shift-4 four times in a row. |
#15 |
HAMMER
i removed all the rear brake parts,and repainted the back plate[EASY].now i have all the brackets,springs,etc.,and i cant figure how they all go.do you have a pic. or diagram???.1986 cj7 thanks dennis |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
