cj7 radiator - JeepForum.com
post #1 of 8 Old 02-10-2003, 11:25 PM Thread Starter
blackdog
cj7 radiator
I want to put a new radiator in my
85 cj7 and I want to upgrade to a
three row. When I call to order one,
however, I get asked if the cap is
in the center or on the drivers side.
My original 2 row has the cap in
the center. The problem I seem to be
running into is no one has a 3 row
for the center cap option. The question
I have is ... what's the difference between
the center cap and driver's side cap
radiators? Is it a mounting or
inlet issue or what? Is this something
I should be concerned about when
ordering???
Thanks,
Mike
85 CJ-7 258 with MPI
blackdog is offline
post #2 of 8 Old 02-11-2003, 12:02 AM
RODDOR
I don't know the answer either, but I would like to know. All of the radiators I've had in past CJ's all had the filler cap on the side. I am doing a build up on a 85 CJ7 that had a four cyl engine and the radiator is gone. I am going to put a 6cyl in it and I don't have the radiator from the donor CJ and I was wondering if the engines would be the difference.
RODDOR is offline
post #3 of 8 Old 02-11-2003, 12:32 AM
only in a jeep cj
Did you check the major players? 4 wheel drive hardware.....Quadratec, etc? they should have one. I went with the center cap 3 row on my 86 and the temp went from 1/2 normal and 3/4 on really hot days/hard driving to 1/3 all the time now. Also change the fluid and therostat at the same time.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 8 Old 02-11-2003, 08:56 AM
dana60cj
dana60cj's Avatar
I have a 4 core Performance Radiator. The thing is big, and stays cool. Their site does ask You the same thing about the cap though. They could tell You why, I don't see much reason, mabey the hoses are different. Seems like the only reason they would ask is because of the overflow tube and where it resides. But who knows.
http://www.performanceradiator.com/
'84 CJ-7, 6" lift, 33" BFG's, I6, .030 Over, Comp Cam, 400cfm Weber, K&N, T-18, 4 Core, Snorkel, D60 Detroit, Custom CV Driveshaft, 1350 U-Joints, D30 True Trac, Alloy shafts, S.R.S. w/ buggy springs, Custom Folding Shackles and Spring Hinges, Custum Tire Rack, Designed On Board Air, Optima's. Sneaky Jeep Owner #3.
dana60cj is offline
post #5 of 8 Old 02-11-2003, 09:05 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Hmmm - never seen a radiator cap on the side in a CJ, either I-6 or V-8....I run the 3 row with my 360 and it's fine.
This is a good place to get what you need though..
Radiators.com
Steve
OldJeepguy is offline
post #6 of 8 Old 02-11-2003, 09:21 AM
Infedel
I ordered a 3 core to repalce my 2 core a couple years back in my '84 CJ-7. I got it from Radiatorexpress.com . The cap was on the drivers side though. I can't imagine that where you put the fluid in, matters at all. Really, that's all that you would be changing.
Infedel is offline
post #7 of 8 Old 02-11-2003, 03:00 PM
habman
habman's Avatar
4wd Hardware has a 3 row, and I beleive a 4 row.
HABMAN
PURPLE JEEP CLUB MEMBER #0
1977 CJ-7 with all stainless hardware, fittings. hoses and lines.
Glass body in fresh Imron Medium Royal Plum Purple with bright freaking yellow interior.
New Tuffy Stereo Security Console
New BesTop Supertop
Full 8 point cage with frame ties.
33 X 12.50 Yokohama AT + II, I dumped my FRENCH made BFG's
400cid Chevy SB and 350 Turbo trans
All fresh from an off frame resto summer of 02, but is it ever really finished?
habman is offline
post #8 of 8 Old 02-11-2003, 11:51 PM Thread Starter
blackdog
Ok, for those still interested I found
out today what the difference is. The
dimensions of the two radiators are
different. The top to bottom dimension
of the center cap radiator is 15"
where the driver's side cap radiator
is 17". Supposedly the mount is the
same. The only problem with switching
radiators lies in the fact that the
shrouds are different.
Mike
blackdog is offline
Radiator Hoses for AMC 360 to CJ Radiator Rollbar Jeep CJ Forum 2 04-18-2009 11:45 AM
4 cyl radiator in a 6 cyl CJ drespecki Jeep CJ Forum 8 08-18-2007 09:27 PM
new radiator ?'s BANISHD Jeep CJ Forum 1 07-13-2007 12:09 AM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
CJ7 radiator rtsurfer Jeep CJ Forum 6 06-03-2006 04:54 PM
