cj7 radiator - JeepForum.com
post #1 of 27 Old 07-03-2011, 05:44 PM Thread Starter
roadtoad85
cj7 radiator
iv now am at a lose i have ordered and gotten 4 radiators now claiming that they fit the 85 cj7 but none have anyone run into to this pblm ??? in about to junk the jeep being i cant find someone to relie on on as far as parts
roadtoad85 is offline
post #2 of 27 Old 07-03-2011, 06:11 PM
BagusJeep
1981 CJ7
Are you using part no. J536 2165?
If you have the 258 (your profile does not say) there were only 2 radiators in 1985, the heavy duty and the non-heavy duty (part listed above).
You do not say how it does not fit but I presume it is a physical fitting to the vehicle. The hoses presumably fit as they only come one way and are simple so is it the mounting to the body?
If your radiator is peculiar then is it a recore needed? If so could a local radiator specialist not fix it?
Lastly, if junking the CJ, could you fit it in a container and ship it to me?
BagusJeep is offline
post #3 of 27 Old 07-03-2011, 08:05 PM Thread Starter
roadtoad85
hey bagus thanks for the info im working with a 258 stock with clutch fan and stock cowl 4 time now i have ordered a radiator so called to fit the 85 all have been the same the hd down to the cheapy the pblm is the set back on the mounting tags mine the org is set back about an inch and 1/2 all the ones im getting are flush mount thus the fan is into the core im at a road block now do i order 1 more time are just have the old one recored due to the fact the after market ones suck donkey
post #4 of 27 Old 07-03-2011, 08:17 PM
PERK
sounds like your getting 3 core radiators instead of the 2core..make sure you order 2 core if you have the clutch fan .
PERK is offline
post #5 of 27 Old 07-03-2011, 09:04 PM Thread Starter
roadtoad85
thanks perk but now im thinking 1 row is the ticket but who has them ??? i wish i could talk to someone who knows more about this
post #6 of 27 Old 07-04-2011, 12:00 AM
BagusJeep
1981 CJ7
There are indeed different offsets, looking at the parts manual they range from being a 258ci radiator with the mounting lugs on brackets on the back of the radiator (hence radiator fully forward) to the 4 cylinder which is on the front (hence radiator some way into the engine bay).
If you have the shroud and the fan drive then they were mated to part number J536 2492 1 which is the heavy duty cooling radiator. This indeed is set some way into the grille area and looks like it has the central radiator cap. The height of the radiators is different and they may have different cowls so worth checking you are gettung a like for like replacement.
post #7 of 27 Old 07-04-2011, 06:31 AM
CJunk
If you have a fan clutch, you need the radiator with the cap offset. Not the one with the cap in the center. I went through this at auto zone and the guy gave up trying to order one. They were the wrong ones or out of stock(correct one). Just go have it re-cored and avoid the PITA.
CJunk is offline
post #8 of 27 Old 07-04-2011, 07:13 AM
MoC
Guys I have been running a 3 core V8 radiator (Think I told them 1978) from Advanced with a center cap and fan clutch for over 2 years now and have zero problems..
MoC is offline
post #9 of 27 Old 07-04-2011, 07:55 AM
CJunk
I guess depending on where you get it, they must be made differently. The one I got would definitly not fit (center cap).
CJunk is offline
post #10 of 27 Old 07-04-2011, 08:21 AM
MoC
Mine was made by Ready-Rad
MoC is offline
post #11 of 27 Old 07-04-2011, 09:27 AM
brownbagg
1930 MK Compass
instead of trying to buy the high dollar aluminum crap that you dont need, just go to your local radiator shop it get what you need the first time. it be cheaper, quicker and guarantee to fit
brownbagg is offline
post #12 of 27 Old 07-04-2011, 09:36 AM
MoC
Who said anything about high dollar aluminum crap that you dont need? Mine was $179 at the time, got it the first time, was quick, and has a lifetime warranty from advanced.....
MoC is offline
post #13 of 27 Old 07-04-2011, 09:45 AM
nshefbuch
1982 CJ7
I use jegs universal aluminum radiator. Has 2- one inch cores, made in America and was $180. Granted I had to have universal mounts welded on but I have $200 total in it and worth every cent.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #14 of 27 Old 07-04-2011, 09:53 AM
L78THUMPER
2007 MK Compass
Brown bag with another dumb a$$ statment!!!! GO figure. By the way DUMB A$$ I'am running one of your not needed ALUMINUM Raid. And not haveing any problems and was not expencive. NOW WHAT??????
Guys please let me play Monster Jeep and run over his junk jeeps PLEASE!!!!!!!!!!!!
L78THUMPER is offline
post #15 of 27 Old 07-04-2011, 10:02 AM
roadhog304
1973 CJ5
give BTR-radiator.com a try. they can get you what you need i am sure. they specialize in 4wd vehicles.
roadhog304 is offline
Radiator Hoses for AMC 360 to CJ Radiator Rollbar Jeep CJ Forum 2 04-18-2009 11:45 AM
Radiator help... billymadison Jeep CJ Forum 5 11-24-2007 07:20 AM
Radiator howelljeep Jeep CJ Forum 5 10-02-2007 02:55 PM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
V6 CJ5 radiator MS-redneck Jeep CJ Forum 1 04-05-2006 11:11 PM
