Cj7 proportioning valve bracket - JeepForum.com
post #1 of 12 Old 05-06-2013, 05:23 PM Thread Starter
mirage100
1976 CJ7
Can anyone tell me where I can get the bracket that goes in between the frame and proportioning? This is for a 84 CJ7
mirage100 is offline
post #2 of 12 Old 05-06-2013, 05:24 PM
skizriz
1978 CJ7
I never knew there was one. Mine's just bolted directly to the frame.
skizriz is offline
post #3 of 12 Old 05-06-2013, 05:52 PM
offroadz
1980 CJ7
I would contact these guys.
http://mbmbrakeboosters.com/index.ph...id=30&Itemid=6
Here are some parts but not sure if they match 100%
http://mbmbrakeboosters.com/index.ph...2&Itemid=6
offroadz is offline
post #4 of 12 Old 05-06-2013, 05:57 PM Thread Starter
mirage100
1976 CJ7
I don't know if I need it
post #5 of 12 Old 05-06-2013, 05:59 PM
offroadz
1980 CJ7
This probably helps you see what it all does.
offroadz is offline
post #6 of 12 Old 05-06-2013, 06:14 PM
MoC
There are one or two on eBay
MoC is offline
post #7 of 12 Old 05-07-2013, 04:36 AM
lugnut28
lugnut28's Avatar
Here's one
http://www.collinsbrosjeep.com/main.htm
Look under nos chassis parts
lugnut28 is offline
post #8 of 12 Old 05-07-2013, 08:22 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I mounted mine to the frame. Never had 1, and would need header clearance anyway.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #9 of 12 Old 05-07-2013, 01:16 PM
agear
I suspect you could also make one. Its just a bent piece of steel with holes drilled in it.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #10 of 12 Old 05-07-2013, 03:30 PM
Jeeprage
Jeeprage's Avatar
I may have one laying around. PM me so that i remember to look for you.
2015 JKU - 6m
Jeeprage is offline
post #11 of 12 Old 05-07-2013, 04:19 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, Collinsbrosjeep.com has them for sale and not to bad of a price for $8.00.
CJ Brake Tube to Frame Mounting Bracket J5356586$7.95
1984 CJ-7 Renegade
keith460 is offline
post #12 of 12 Old 05-07-2013, 07:54 PM Thread Starter
mirage100
1976 CJ7
Thanks guys . I ordered one from Collins Bros:
