CJ7 progress pics - Page 5 - JeepForum.com
post #61 of 107 Old 04-14-2009, 05:11 PM
sail78385
Is that a quadratrac transfercase? Looks differnt then mine, maybe I have the one with the low option on it??
sail78385 is offline
post #62 of 107 Old 04-17-2009, 07:40 PM
bigjoe
1977 CJ7
Nice to see in the last photo that you have a help in the shop. My boys always like to help me when I'm working on the Jeeps.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #63 of 107 Old 06-14-2009, 10:23 AM Thread Starter
jeepsterdk
1978 CJ7
May 30. 2009
Got most of my exhaust system finished today. Everything but the headers are made of 304 stainless steel. I hand-polished the pipes from the glasspacks and back. Damn, that took some time and buds!
1978 CJ7 | 360 AMC | TH400 | AMC20 | YJ springs
jeepsterdk is offline
post #64 of 107 Old 06-14-2009, 10:26 AM Thread Starter
jeepsterdk
1978 CJ7
June 14. 2009
Put on a new oil pan. The old one got too beat up when I took it off to replace the oil pipe.
post #65 of 107 Old 06-24-2009, 03:29 PM Thread Starter
jeepsterdk
1978 CJ7
june 24. 2009
Well, for some reason I felt the urge to do a little painting today. I started painting the heater stuff. It was very dirty and the adjuster system was stock. After a good cleaning and some WD40, it worked like new again.
The blower engine is toast so a new one is on it's way. Need to clean the housing first
Can someone tell me what this rusted out dingy is? Do I need it or could I just let be that way?
Here you can see the rusted part again. It's just below the blower motor
The duct housing painted matte black.
Got my front driveshaft in place
And finally a pic of my new HEI dizzy with LiveWires
post #66 of 107 Old 06-24-2009, 05:38 PM
tankcj
tankcj's Avatar
Great build!...keep the updates coming!!!...
2011 2dr Rubicon Auto, AEV 3.5" Premium, PSC Brawler Lite front bumper and skid, Evap skid, Raceline Monster beadlocks, 35" KM2s, 5.13 gears, Trailgater, Expedition One rear Bumper and Tire Carrier, ACE Rock Sliders, Warn Powerplant, ORW trans cooler
tankcj is offline
post #67 of 107 Old 07-25-2009, 01:45 AM Thread Starter
jeepsterdk
1978 CJ7
19. july 2009
Figured I needed a fuel pressure gauge to help me dial in the TBI system. I chose one that is liquid filled so that it is easier to read when the engine is running
I also finished wrapping the driver side header with ThermoTech. What a pain in the a**. There are many oppinions on wrapping the headers. I will only be driving this Jeep on sunny days so I don't worry about the tape being wet and causing the headers to rust. I have had great succes with wrap on other projects, so it was naturally for me to use it on this one also
It is no secret that Fatman is one of my greatest inispirations and I truly admire his work. In an attempt to copy his skills, I was pretty sure, that the first step in reaching my goal, was to get a pair of safety flip-flops
post #68 of 107 Old 07-25-2009, 03:15 PM
ramstang
1976 CJ5
I love the progress. It looks great.
ramstang is offline
post #69 of 107 Old 07-25-2009, 03:58 PM
JKM3134
1983 CJ7
That rusted out thingy is a drain tube for the blower housing. After the housing is installed there is an "L" shaped rubber hose that caps the tube and directs the water away from the firewall and onto the ground.
JKM3134 is offline
post #70 of 107 Old 07-25-2009, 04:16 PM
Fatman
Fatman's Avatar
2008 CJ7
LOL, that's just funny as hell.
This is a great loking build, really enjoy the attn to detail !
Love the V8. Matter of Fact, this winter I'm going to start a 454 swap into the Yellow Jeep. Have my 6.32 ratio T-18, all I need to do is find the right block to build.
I've got about $2,500+ into my existing 4.2 that I'm going to have to part out in the fall to pay for the new build.
Keep up the good work!
Thread Links:
Fatman is offline
post #71 of 107 Old 07-25-2009, 04:31 PM Thread Starter
jeepsterdk
1978 CJ7
Love the V8. Matter of Fact, this winter I'm going to start a 454 swap into the Yellow Jeep. Have my 6.69 ratio T-18, all I need to do is find the right block to build.
Thank you very much. I had a '76 Cj5 in which I swapped a 454 BBC. Scary with all that HP and Torque in a '5. Here's a pic of it
post #72 of 107 Old 10-21-2009, 01:04 PM Thread Starter
jeepsterdk
1978 CJ7
october 21. 2009
Got my 4wd fiberglass tub and one piece front end. Both things are looking great and I'm looking forward to get started on them
Can anyone help me with figuring out where to connect these things on the trans/transfer
post #73 of 107 Old 10-21-2009, 01:16 PM
tankcj
tankcj's Avatar
The one on the TC is for the 'Emergency Drive' light and the one on the trans (I believe) is for the reverse lights .
tankcj is offline
post #74 of 107 Old 10-22-2009, 10:13 AM Thread Starter
jeepsterdk
1978 CJ7
October 21. 2009
Today was a very good day! I got my fiberglass tub mounted. It's starting to look like a Jeep again. I used the body mounting kit from 4wd.com. I cut the body rubber for outriggers 2 and 3 at 2". Do you guys think I have enough room for 35" tires? I plan on using TJ flares and trim the body for more clearance. The tires on it now are 33" on 8" rims
post #75 of 107 Old 10-22-2009, 10:27 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
The one on the trans is the kickdown/passing gear switch.
Your reverse lights/neutral safety combo switch should be mounted to your steering column.
LT1CJ7 is offline
Windshield replacement in progress. Pics twoleos617 Jeep CJ Forum 2 09-13-2009 10:11 PM
OMG, I Can't Believe This......Progress Pics Military Jeeper Jeep CJ Forum 15 09-22-2008 02:05 AM
Progress on build pics and a question My1978CJ7 Jeep CJ Forum 4 06-23-2008 08:47 PM
Progress on Paint Job cont... (Warning lots of big pics) BigMike20 Jeep CJ Forum 6 08-22-2005 07:01 PM
some progress.. kasper37 Jeep CJ Forum 3 09-08-2002 01:17 PM
