CJ7 progress pics - Page 4 - JeepForum.com
post #46 of 107 Old 01-15-2009, 03:34 PM
bigjoe
1977 CJ7
Nice job. Have one question, since you had the M20 apart why not change to one-piece axles? I know you don't have to and all just wondering why not upgrade? And nice job again.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #47 of 107 Old 01-16-2009, 02:29 AM Thread Starter
jeepsterdk
1978 CJ7
Thank you very much. Many people have asked me this question, but I decided to go with the stock axles because I won't be using the Jeep for serious wheeling and I don't have a big engine. The 304 isn't exactly a monster
1978 CJ7 | 360 AMC | TH400 | AMC20 | YJ springs
jeepsterdk is offline
post #48 of 107 Old 01-16-2009, 07:16 AM
Rollbar
1984 CJ8
I have wheeled w/two piece axles for a long time and one was behind the 304. It's the right foot equation most of the time. I've never had a problem w/them.
P.S. Carry a couple of nickles cut in half just in case U need a key-way
<----Click
<---- Click
Rollbar is offline
post #49 of 107 Old 02-04-2009, 06:23 AM Thread Starter
jeepsterdk
1978 CJ7
Made a little progress and also took a step back!
Here's the reason: The oil dipstick tube for the engine had snapped just where it meets the block. That meant, that the other half of the tube was stock in the block. Taking the advice from a friend, I used a self-tapping screw to catch the little piece in the block and tried to pull it up. No luck. And then suddenly I heard that awful, awful sound "pling-pling". The tube broke off and fell down in the oilpan. I yelled a lot of words not fit to be mentioned at a public forum! Well, pulled the oil pan and found the little bastard just lying there laughing at me....bad day! Finished the day with installing the TBI unit
The day after I started making a template for my exhaust system. Yes, the spot welds are ugly, but since it's only a template, I guess it doesn't matter that much . I made the template in 3" steel tubing. The finished exhaust will be made of 3" stainless steel tubing instead and welded with a TIG welder by a pro
post #50 of 107 Old 02-04-2009, 07:25 AM
bigjoe
1977 CJ7
Nice little engine you got there. Sorry about the dipstick issue. I have the same trouble on one I have here. Just waiting for spring to drop the pan.
bigjoe is offline
post #51 of 107 Old 02-04-2009, 11:03 AM
martyweir
1976 CJ7
OOOO man! Din't think about it falling in. Same trouble w/ my sbc - dipstick tube broke off @ block. I just kinda let mine dangle for now! Gotta think of a way to get her outa there without haveing to pull the oil pan for the 3rd time in a year... Never any fun.
BTW - that "mockup" exhaust looks better than my permanent system!!! Nice clean work.
martyweir is offline
post #52 of 107 Old 02-04-2009, 11:11 AM
chadlow
1992 XJ Cherokee
I'm freakin JEALOUS!!!
ZeroDog Designs custom airbrushing and vinyl work
chadlow is offline
post #53 of 107 Old 02-04-2009, 04:52 PM
Patter
1981 CJ5
Very nice job Jeepsterdk. I am new at this jeep thing. I am on the front end of a complete build myself. Will post pics some year I have a question for you. In post #33 picture, the "bottom" of the shackles point towards the rear of the jeep. For some reason, I was thinking that they should point towards the front, and the bottom of the rear shackles, toward the rear. I know this is in part due to spring length,etc. Does it matter? Could you shed some light on this matter for a rookie? Thanks.
Again, awesome job. Keep it up.
Patter is offline
post #54 of 107 Old 02-04-2009, 09:26 PM
jatepper
Just caught wind of this thread. Nice job man! Want to see some pics of that tub your putting on that thing!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #55 of 107 Old 02-05-2009, 04:26 AM Thread Starter
jeepsterdk
1978 CJ7
Thank you very much. The reason the shackles are pointing towards the rear, is that the springs are brand new, and they haven't settled yet. It's much better now 'cause the engine and trans are in.
post #56 of 107 Old 02-05-2009, 04:22 PM
poppatello
to pretty for me. I wouldn't want to worry about cleaning this trailer queen...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #57 of 107 Old 02-05-2009, 04:41 PM
Bakunin
Bakunin's Avatar
A long time ago I was working on a SBC and had the carb off, so I wisely (cough) used an old pair of overalls to cover the carb opening on the intake while I worked. Well, I didn't realize it but the old zipper was worn and fell into my intake! Started it up later and ooooh the noise. Had to pull the head and get the valve reground...little thing was sitting there on top of a piston, laughing at me.
Bakunin is offline
post #58 of 107 Old 02-19-2009, 01:12 AM Thread Starter
jeepsterdk
1978 CJ7
February 16-19. 2009
I started working on the wiring for the TBI. Pretty simple when following the instructions. Yes, I actually followed the included instructions this time . I didn't remember how the brackets for the power steering was meant to be, so I tried to fit them and I think they are ok?
Time to do the fuel line routing. Use Russell hose which then connected to copper piping. I still need some hangers for the tubing though. The bracket on the cross member is for the Holley fuel pump. It is actually made from an old stainless entry step I had lying around
post #59 of 107 Old 02-19-2009, 04:08 AM
CSCmrwizard
1982 CJ5
take some grease and put in the dipstick tube then a tap that will screw in but not have a hole lot of pressure just a bit to grab the tube then take a nut and run it down the tap if you be eazy on it u will get her out
the grease is to keep stuff from falling in the pan
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #60 of 107 Old 04-14-2009, 01:07 PM Thread Starter
jeepsterdk
1978 CJ7
april 13. 2009
Just started polishing the exhaust I made in stainless steel. Man, this is hard work! Using a polishing cloth on an electric drill with some compound on it. I have only used the rough compound until now, but I will be using the finer compound afterwards to get a mirror finish. The pics give a little idea of the finished project...without the fine compound that is
The mini-me working on the Peg Perego is my 4 year old son. He means the world to me and I'm so proud of him. I asked him what he was doing and he said: "Nothing dad, just makin' the Jeep run again. It's broken once more". Yeah well....
Windshield replacement in progress. Pics twoleos617 Jeep CJ Forum 2 09-13-2009 09:11 PM
OMG, I Can't Believe This......Progress Pics Military Jeeper Jeep CJ Forum 15 09-22-2008 01:05 AM
Progress on build pics and a question My1978CJ7 Jeep CJ Forum 4 06-23-2008 07:47 PM
Progress on Paint Job cont... (Warning lots of big pics) BigMike20 Jeep CJ Forum 6 08-22-2005 06:01 PM
some progress.. kasper37 Jeep CJ Forum 3 09-08-2002 12:17 PM
