CJ7 Passenger Door will NOT OPEN! - Page 2 - JeepForum.com
post #16 of 32 Old 08-14-2010, 09:12 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Which type of lock do you have (locks on to a pin or has a latch like a house door)?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #17 of 32 Old 08-14-2010, 09:15 PM
JeepsOLot
On my full door, I had to resort to taking an angle cutter to the plate that the latch attaches to the side of the door, and cut it. Then, I was able to move the two latch cams out of the way, freeing the door. The reason mine would not open was, the spring that releases the cams off the striker pin broke. I didn't know this until I cut the plate off.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #18 of 32 Old 08-14-2010, 09:53 PM
gojeepin
1983 CJ7
I took the panel off and pulled on the rod that connects to the inside door handle lock lever.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #19 of 32 Old 08-15-2010, 07:00 AM Thread Starter
N3wRev
Finally got the door off. Decided to unbolt the hinges on the door and sort of lifted it out.
...I go topless! Even when it rains... :D
N3wRev is offline
post #20 of 32 Old 08-15-2010, 07:09 AM
walkerhoundvm
1981 CJ8
Excellent, now's the time where my link way up top will come in handy trying to get it fixed!
-N
walkerhoundvm is offline
post #21 of 32 Old 08-16-2010, 10:58 AM Thread Starter
N3wRev
Well in the process I think i may have done more damage then it originally had...just going to buy a new lock mechanism.... But thanks a whole lot to everyone for the advice!
N3wRev is offline
post #22 of 32 Old 08-22-2010, 11:42 PM
kwkouki
when in doubt...rip it out!
kwkouki is offline
post #23 of 32 Old 03-17-2014, 05:14 PM
PeterPatrickCJ7
1981 CJ7
My door is stuck too. I've tried everything except for taking the panel off. Can anyone suggest the easiest way to do this while the door is still on?
PeterPatrickCJ7 is offline
post #24 of 32 Old 03-18-2014, 12:14 AM
1978CJ7Beast
1978 CJ7
For me, i sprayed a ton of PB blaster into the interior lock mechanism from lots of angles. Next...roll down the window all the way...aim a flashlight in there.. and jiggle the handle... You can spray PB blaster right on the seized/barely moving parts if you have good aim.
After letting the pb blaster sit and penetrate for a bit....start working the lock handles back and forth (one hand working the inside...and the other hand working the outside simultaneously.). Eventually, i was able to free mine this way.
"What will all that chatter and hearsay count (will you even be able to remember it?) when the anaesthetic fog which we call "nature" or "the real world" fades away and the Presence in which you have always stood becomes palpable, immediate, and unavoidable? - C.S. Lewis"
1978CJ7Beast is offline
post #25 of 32 Old 03-18-2014, 12:31 AM
crouse11c
First does the door handle go through it whole motion or does it get stuck 1/2 or 3/4 the way through. I will tell you what is causing which ever if is. I am a magnet for buying doors that love to break. Be careful messing with it. Those handle don't fit well an on to very thin clip hold it in place.
If it moves through the whole motion and nothing happens. Then there is no fix and you will have to open the panel. Not that hard really. I would do this for any of them.
If it only goes 1/2 then something is bent inside, almost always the locking linkage has bent most likely cause of your window catching it and making it stick or worse. You will have to remove panel or get lucky and it work again. You can pop the lockin. Button out but you mostly will damage it and it might not even help. Remove panel or if the inside lock button doesn't work right remove the inside door handle and inspect.
3/4 of the way. It is caused by a miss adjusted linkage in the opening linkage. There is a knob on the bottom of the inside of your handle and this part o the linkage a small lever should not pass this. Most likely it gets stuck around 3/4 and you have to push the handle back in. The best fix for this is a hammer if stuck, or a slim Jim. I have done both. But once again pull the panel very easy just remember you prob want to get some new adhesive to put it back on.
No mater which one it is remove panel take out to retaining clips on handles inside that holds the handle to door. Then from the out side pull the handle away from the door and press down on whole handle. If it doesn't open the door you have a lock issue.
Last hit that shat with a hammer, rubber of course!! It makes you feel better
crouse11c is offline
post #26 of 32 Old 03-18-2014, 04:27 AM
waterdowg
My Drivers door will not open with out much force, but that is because the boddy is rotting an starting to colapases. Its not really notice able. I did not realize it until I put my hard top ans doors on for the winter. The drivers door would not close correctly.
waterdowg is offline
post #27 of 32 Old 03-19-2014, 09:11 AM
PeterPatrickCJ7
1981 CJ7
Mine is the first, you can pull both door handles and nothing happens. If you insert key in the door it will make a sound lock to unlock but nothing happens.
When I take the inside door handle off I can see the rods connecting the door handle to the lock. Do I disconnect at this point? Do I work on the door from this small area inside the door or do I need to physically rip off the whole door panel to get inside there to try to free the door?
I don't want to break anything that is not neccesary to get the thing opened. I ordered soft doors s this will not be a problem anymore!
post #28 of 32 Old 03-19-2014, 09:27 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Peter,
You're problem is most likely at the latch side of the door, not the handle, so the panel will need to come off. It's not difficult, but you'll probably snap a few of the plastic clips that hold the panel in place. You can buy replacements for them.
I highly recommend you check out the link walkerhound provided early on in this thread.
Matt
Matt1981CJ7 is offline
post #29 of 32 Old 03-19-2014, 12:02 PM
PeterPatrickCJ7
1981 CJ7
Originally Posted by Matt1981CJ7 View Post
Peter,
Matt
Thanks Matt,
Very helpful. I will try that when I get home today. I keep clicking that link and it says no thread specified. Do I need to be a member to view it?
post #30 of 32 Old 03-19-2014, 07:20 PM
PeterPatrickCJ7
1981 CJ7
Peter,
Matt
I was able to remove the door panel and wrestle with the pins. It eventually opened and the doors are off. Thanks for your help on this. Now to buy a working door to steal all the parts needed to make mine work.
Thank you again.
1985 , cj7 , door , stuck
86 CJ7 door will not open. lukless Jeep CJ Forum 4 06-29-2010 11:44 PM
help cant open passenger door rusty83cj Jeep CJ Forum 2 12-03-2008 09:48 AM
Door won't open yucatanstan Jeep CJ Forum 6 05-04-2007 04:00 PM
CJ7 door won't open alienball Jeep CJ Forum 5 05-23-2006 07:11 AM
