CJ7 Passenger Door will NOT OPEN! - JeepForum.com
post #1 of 32 Old 08-11-2010, 04:02 AM Thread Starter
N3wRev
Went for a ride in the Jeep one day. Opened the passenger door, got in and shut it. Came back...I couldnt get out. I tried locking and unlocking (the lock was sticking and hard to maneuver) and it wouldnt really work. I pulled the handle...no luck. Tried the outside handle...No luck. Took the panel off the door, but no clue as to what I am acually looking at to fix.
...I go topless! Even when it rains... :D
N3wRev is offline
post #2 of 32 Old 08-11-2010, 02:56 PM
jeep360limited
They come with doors?
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #3 of 32 Old 08-11-2010, 03:17 PM
walkerhoundvm
1981 CJ8
Here is the best reference I've found for repairing doors - you can thank JScherb, wisest of all the wise in repair and fabrication.
JScherb's door repair thread (CJ8.com)
While I haven't sifted through it, I plan to when I fix my doors up this winter.
-N
walkerhoundvm is offline
post #4 of 32 Old 08-11-2010, 05:31 PM Thread Starter
N3wRev
That reference is excellent..However, does not address the issue that the door is stuck shut. I can't get it open or off the vehicle.
N3wRev is offline
post #5 of 32 Old 08-11-2010, 06:39 PM
Dustlander
1979 CJ7
can you get in and unbolt the door striker? (the bolt thingy that sticks out and the door latches on to)
that's what i had to do to my dads when his got stuck
Dustlander is offline
post #6 of 32 Old 08-11-2010, 10:49 PM Thread Starter
N3wRev
I'm going to try that when I get home from work in the morning.
N3wRev is offline
post #7 of 32 Old 08-12-2010, 06:26 AM
Guitar
I noticed that when I put the passenger side hard door on mine the other day, the outside handle wouldn't allow it to open, and it wouldn't lock/unlock.
1984 Blue CJ7 Renegade
Guitar is offline
post #8 of 32 Old 08-12-2010, 10:14 AM
Gunga
1978 CJ7
What are you doing in the passenger side? Why aren't you driving?
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #9 of 32 Old 08-12-2010, 11:08 AM
CjinPA
CjinPA's Avatar
Have you tried turning the lock cylinder with the key to see if that solves your problem with opening the door? The rod that goes from the inside lock button (near the interior handle to open the door) might need to be bent a little so it moves the vock mechanism just a little more. The latch assembly might be gunked up and need to be cleaned.
If turning the lock cylinder with the key doesn't work you have two options.
1. take the interior door handle out and try pulling on the rods that go from the handle and lock switch to the door latch to see if the door opens.
2. You will need to remove the interior door panel. Then take the screws out of the metal panel that covers the latch assembly in the door. You wont be able to get at the four screws on the rear edge of the door that hold the metal panel on so you will need to bend it to get to the latch assembly. Once you can get to the latch just pull or push on the rod that goes from the lock cylinder to the latch and try to open the door.
Once you get the door open I would spray some degreaser on the latch to clean it and see if that solves your problem. If not you will need to slightly bend the rod that go from the latch to the lock cylinder as well as the rod that goes to the interior door lock button.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #10 of 32 Old 08-12-2010, 05:40 PM Thread Starter
N3wRev
Unbolting cylinder did not work. Key does not unlock it... Will try your suggestion Cjin
N3wRev is offline
post #11 of 32 Old 08-13-2010, 08:21 AM
JeePete
1983 CJ7
Mine did this too. Try this....
At the same time, pull the inside and outside levers. You can do it with the window down.
Something goes "ka-flu-ee" (technical term) inside the door.
Hope this helps.....
JeePete is offline
post #12 of 32 Old 08-13-2010, 11:16 AM
mxdano
1982 CJ7
Mine has done this several times. The latching mechanism gets gummed up inside the door and the levers don't touch it when you pull on them. When mine does it, I beat on the door right at the lock with my hand and eventually it vibrates enough to catch. Once you get it open take the inside panel off to where you can get to the latch and spray some good cleaner on all of the linkage pivot points. Then spary some silicone lube back on. This should fix it.
mxdano is offline
post #13 of 32 Old 08-14-2010, 12:04 AM Thread Starter
N3wRev
Been sitting here for an hour and no luck. It won't catch I can't get it to move. Sprayed it down.... Hoping it will loosen up
N3wRev is offline
post #14 of 32 Old 08-14-2010, 11:54 AM Thread Starter
N3wRev
The guy I got the hots for wanted to drive it
still no luck on this door. Have it open and it's not even connected to the lol cylinder and refuses to stay connected. Bout to just cut the striker off. Unbolted that too and still can't do anything.
N3wRev is offline
post #15 of 32 Old 08-14-2010, 09:29 PM
-jeep-jeep-
1983 CJ7
mine did the same thing, but i just kicked it from the inside worked for me, but didnt fix the lock
Jeep # 1 -
- Restoration in progress...very slow progress
Jeep # 2 -
- 31x10.5R15 Pro Comp Extreme mt's - 4.0 HO head - MC2100
Jeep # 3 - 1990 Cherokee - 4.0, AW4, dana 30 HP, dana 35 -31x10.5 R15 mud terrains, 2" PNP lift.....Gone to the crusher
Jeep # 4 - 1999 wj stock and still pretty
-jeep-jeep- is offline
1985 , cj7 , door , stuck
86 CJ7 door will not open. lukless Jeep CJ Forum 4 06-30-2010 12:44 AM
help cant open passenger door rusty83cj Jeep CJ Forum 2 12-03-2008 10:48 AM
Door won't open yucatanstan Jeep CJ Forum 6 05-04-2007 05:00 PM
CJ7 door won't open alienball Jeep CJ Forum 5 05-23-2006 08:11 AM
