cj7 over heating ????? or funky guage - JeepForum.com
post #1 of 4 Old 05-24-2003, 12:27 PM Thread Starter
maestro
Question cj7 over heating ????? or funky guage
85 cj7 with 258 and fuel injection+borla header
first of all i gotta mention my whole dash has a short or a bad ground...
until recently my only problems have been a dancing voltmeter
but now my temp guage within the last few days has been saying that the engine is running too hot. there are no visiable signs that it is over heating, no smoke, or loss of radiator fluid but it keeps going from fine to redline while i drive
im wondering how possible its just the guage going nuts or could it be that i need a new water pump anyone got any ideas
im gunna throw in a new guage this afternoon and see what happens
any other opinions would be helpful
1985 jeep cj7,258 with mopar MPI, borla header, custom flowmaster exhaust, 1.5 inch body lift, 3.5 inche suspension lift 31inch tires,mean green alternator
maestro is offline
post #2 of 4 Old 05-24-2003, 12:38 PM
rok_toy
rok_toy's Avatar
Header!!!
I went through the same problem. I checked the temp in the radiator, with a meat thermometer. It said I was at 170 degrees, about normal. The guage was reading almost at the hot end of the spectrum.
What I found is the heat coming off the header was heating up the sending unit. Try puting some type of heat shield between the sending unit and header.
Let me know how it goes.
1986 CJ-7, 258/T5/Dana300, Dana 44's, 4.89's, ARB's, SOA, Warn8K, high-steer, 37" MTR's, onboard air( york style)...more to come!!
rok_toy is offline
post #3 of 4 Old 05-26-2003, 07:23 AM Thread Starter
maestro
tried putting in a new temp guage but the damn thing didnt fit, ended up being a bad ground on the dashboard i dunno how that effects the temp guage.
thanks for the suggestion though ill keep it in mind if i have any future probs.
THANKS!!!
maestro is offline
post #4 of 4 Old 05-27-2003, 02:58 AM
Popol
Popol's Avatar
I still have this problem I live in a hot climate anyway, so the first thing i did was to take out the thermostat as a precautionary measure. The temperature gauge still says the same, goes to over off the scale in no time at all.
Process of elimination tells me that the engine temperature is now ok, (I measured it also using a meat thermometer, its within limits), so either the gauge is faulty or the temperature sender is faulty, next is to change the temperature sender and see if that clears the problem, if it doesnt then ill change the gauge..
Popol is offline
Funky hose on bottom of intake manifold 76driver Jeep CJ Forum 7 10-19-2008 01:30 PM
Funky noise in 4wd, not so bad in 2wd aztitan Jeep CJ Forum 1 09-14-2008 06:35 PM
Gas guage/water temp guage SwampBuggy Jeep CJ Forum 4 08-09-2008 09:02 PM
Nutter - Ruch, Weber funky issues ckentling Jeep CJ Forum 15 04-27-2008 01:04 PM
63 willys over heating barnmantoday Jeep CJ Forum 2 05-03-2004 10:28 AM
