Cj7 no start, completely lost... - JeepForum.com
post #1 of 15 Old 09-07-2013, 09:49 AM Thread Starter
Prspallone
1982 CJ7
My 1982, 258 CID, stick, cj7 is refusing to start. If I turn the key there is a loud CLICK but nothing else. If I try to turn it on with the lights on they go out. then if I go touch these 2 wires with plugs I found dangling (one of the three wires from the ignition coil-red with plug and a black one with a longer plug.) If I keep them grounded it makes no difference trying to start. I am also not seeing a spark coming from the ignition coil plug that feeds to the distributor cap. I tried replacing the ignition coil but still nothing.... could this be a ignition module failure? Can anyone direct me to steps to diagnose what could be wrong without buying a bunch of unneeded parts? Thank you in advance!
Prspallone is offline
post #2 of 15 Old 09-07-2013, 09:58 AM
walkerhoundvm
1981 CJ8
dead battery
walkerhoundvm is offline
post #3 of 15 Old 09-07-2013, 10:02 AM Thread Starter
Prspallone
1982 CJ7
I had the battery tested, 95% charge and I believe 12.6V. Thanks for the reply.
post #4 of 15 Old 09-07-2013, 10:12 AM
walkerhoundvm
1981 CJ8
Brush your battery terminals to make sure there's good contact. Check your ground strap to make sure the battery is able to ground. If all those check out, try a battery from another vehicle that you know works.
The sole click of the starter is a classic sign of either a dead battery or poor grounding/terminal connections.
post #5 of 15 Old 09-07-2013, 10:26 AM Thread Starter
Prspallone
1982 CJ7
Would this cause the lights to go off when I turn the key?
post #6 of 15 Old 09-07-2013, 10:27 AM Thread Starter
Prspallone
1982 CJ7
I assume that this means it is drawing to much current(?) so the lights are not ale to sustain themselves right? how this would relate to the problem I don't know.
post #7 of 15 Old 09-07-2013, 10:41 AM
Jeeper44mag
1978 CJ7
Maybe it draws enough current that the relay for the lights no longer engages?
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #8 of 15 Old 09-07-2013, 11:07 AM
W7NB
Could be a bad starter solenoid. Jumper around it with a jumper cable and see if it turns over properly. If so install new solenoid. Also might be a bad starter. Have someone turn the key and see if you feel the starter trying to engage.
°lllll° Am I broke yet??
1985 CJ7 With HO 4.0 Conversion
2013 JK
W7NB is offline
post #9 of 15 Old 09-07-2013, 11:59 AM
jeepwhore
When the ignition circuit is energized it draws alot of amps. If you're system was functioning properly you'd notice the lights dim slightly when you start it. In your case, there is a restriction in current flow somewhere. So when you try and start it the ignition is sucking the power from wherever it can in an effort to start the Jeep, hence the lights go out.
All the above are good places to start looking. You say the battery was tested, did they do a load test on it as well? In addition to the above suggestions I'd look at your battery cables. The smaller gauge discount store cheap ones can corrode inside the sheathing and restrict the current alot.....first hand experience with that one!
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #10 of 15 Old 09-07-2013, 12:34 PM Thread Starter
Prspallone
1982 CJ7
FIXED! the positive cable was totally corroded but I went and replaced the ignition module at the same time anyway because the plugs looked toasted. Thank you guys!
post #11 of 15 Old 09-08-2013, 11:42 AM
walkerhoundvm
1981 CJ8
post #12 of 15 Old 09-09-2013, 06:13 PM Thread Starter
Prspallone
1982 CJ7
The irony continues...
One of the reasons it was urgent I fixed the problem was because I planned to pull the engine the next day I planned to pull the engine to start a rebuild the next day (I will start a thread when I get a little farther) and I didn't want to do anything unless I knew i could get it running afterwards. Everything went rather smooth, the next day i brought to my school where I will have space to work on it in the engines lab. I went back to my jeep to bring it to the forklift and it wouldn't start. Luckily I realized that it was the EXACT problem I had with my cj. Quick fix and everything is good, but talk about a coincidence!
post #13 of 15 Old 09-09-2013, 06:22 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I recommend a more vigilant maintenance program on your vehicles.
Matt
Matt1981CJ7 is offline
post #14 of 15 Old 09-09-2013, 07:20 PM Thread Starter
Prspallone
1982 CJ7
Matt
In my defense I have only had the cj for 2 1/2 weeks, I have no good excuse for my wrangler though
post #15 of 15 Old 09-09-2013, 08:53 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
That was going to be my suggestion. Also, sometimes a battery cable cable will look OK but somewhere down the line the metal is corroded but hidden by the jacket. Glad you got it running!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
