CJ7 motor swap to a 350. - JeepForum.com
post #1 of 6 Old 07-25-2006, 09:56 AM Thread Starter
86cj7laredo
Ok, I have a 258 I6 that is worn out. I am thinking of doing a swap to a 350. I found a great deal on an LT1 350 motor. What I would like to know is how difficult the swap is. What parts will I need to do the swap. Keep in mind that I want to keep the fuel injection on the motor. Is there any prep work I can do with the 258 still in the jeep to make the swap go easier. Is it worth swapping to the 350 or should I stick with the 258? All opinions and suggestions are welcome. Thank you in advance for your time.
86cj7laredo is offline
post #2 of 6 Old 07-25-2006, 10:40 AM
fuzz401
1978 CJ7
not much you can do with the motor in
you will need a motor mount set up -- adapters for the motor to tranny -- might need new driveshafts or mod them
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 6 Old 07-25-2006, 11:19 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A few things that quickly come to mind...
> Engine Mounts
>Maybe new tranny mount
>Adapter to mate engine/tranny
>Maybe a new tranny to handle stronger motor
>Conversion Radiator
>Conversion Headers or manifolds
>New exhaust
>New hoses
>New fuel lines to handle injection
>Fuel Pump matched to injection system
>Wiring Harness (either complete, splice in or do your own)
>Different driveshafts
>Maybe stronger axles
>Nuts and Bolts
.. that should get you started.
BESRK is offline
post #4 of 6 Old 07-25-2006, 11:51 AM
dblakley
get a 700r4 tranny it will bolt up to the 350 and a dana 300 you will also need the wireing harness and computer from the doner vehicle .
dblakley is offline
post #5 of 6 Old 07-25-2006, 12:03 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Change the cam also, it is setup for RPMs and you will need low end torque for the trails.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #6 of 6 Old 07-25-2006, 12:12 PM
jeepskate
Do some searching & reading, get the swap manual from Advance Adapters. People have been swapping 350's into CJ's for *decades* so there's plenty of info out there. The LT1 is a little more complicated from a wiring standpoint but there are enough resources out there since 350 swaps into just about anything are pretty common that you can easily find places that'll setup your harness for you, burn custom ROM's, etc.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
Motor swap? Texaspipeliner Jeep CJ Forum 7 01-06-2010 08:01 PM
4.2 to a 4.0 FI motor swap help... CJBRENT Jeep CJ Forum 1 08-29-2008 05:03 PM
Motor Swap? CJBRENT Jeep CJ Forum 2 05-08-2008 05:20 AM
motor swap 83renegade Jeep CJ Forum 6 12-08-2005 07:25 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
