CJ7 manual transmission inspection - JeepForum.com
post #1 of 8 Old 02-03-2012, 04:14 PM Thread Starter
mountainking
1983 CJ7
Hi guys, I just got a CJ7 with a T5 that is unable to drive in reverse. I want to inspect it to see exactly what's going on and it's condition. Is it possible for to remove the transmission cover without removing the transmission from the jeep? I've already removed the offset lever and it appears that there is something preventing the transmission cover from removal.
mountainking is offline
post #2 of 8 Old 02-03-2012, 05:13 PM
fredrok
Sorry, gotta remove the tranny
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #3 of 8 Old 02-04-2012, 03:31 PM Thread Starter
mountainking
1983 CJ7
Crap......., that's what I was afraid of. Thanks for the answer fredrok. Anything I should take to caution?
post #4 of 8 Old 02-04-2012, 03:41 PM
fredrok
Well, the list is long! Anyway, some time ago I posted a link to the T5 rebuild manual. I'll search for it later
when I get the chance if you haven't found it first. If you search my posts w my username, you'll
find plenty of T5 info. I've probably rebuilt no fewer than a few hundred. While it's out, I always recommend
a good hard look at the clutch, throwout bearing, flywheel and pilot bushing condition. Also check for
excessive clutch fork wear. You know, all the stuff you don't want to go back in for.
I always suggest a new STEEL input bearing retainer at rebuild.
Many wars have been waged over the proper oil. I use Penzoil or GM synchromesh.
fredrok is offline
post #5 of 8 Old 02-04-2012, 04:02 PM
fredrok
h t t p ://www.ttcautomotive.com/English/onlineorder/pdf/TRSM-T5-0510-R1_173.pdf
Also recommend h t t p ://www.5speeds.com/t5.htm
Take the spaces out of the http. Hey ADMIN, are we no longer allowed to post links?
fredrok is offline
post #6 of 8 Old 02-04-2012, 04:08 PM Thread Starter
mountainking
1983 CJ7
Thanks a million! I already downloaded the T5 rebuild manual actually . I'm thinking that maybe swapping the tranny with another working T5 may save me the headache because I don't have all of the resources required for a rebuild.
post #7 of 8 Old 02-04-2012, 04:10 PM
fredrok
That is a road block for many and probably a good idea if you don't have much experience with them. Good luck
fredrok is offline
post #8 of 8 Old 02-04-2012, 04:15 PM Thread Starter
mountainking
1983 CJ7
Oh I spoke too soon, the rebuild manual in your link is one I do NOT have, yours looks far more definitive. Thanks again!
Manual transmission rchimileski Jeep CJ Forum 2 08-11-2011 10:38 AM
manual transmission oil ? 1940leon Jeep CJ Forum 2 09-08-2010 12:17 PM
Manual Transmission Questions jsc7002 Jeep CJ Forum 17 04-16-2009 01:36 PM
350 Ram Jet...what manual transmission should I get??? jpre32 Jeep CJ Forum 12 03-12-2009 11:25 PM
How to Identify my Transmission: 3sp Manual OCDWheeler Jeep CJ Forum 3 02-15-2009 05:53 PM
