CJ7 leaning towards driver's side - JeepForum.com
post #1 of 8 Old 02-27-2010, 07:32 PM Thread Starter
CALOcruiser
CALOcruiser's Avatar
1978 CJ7
My "new" '78 CJ7 is almost 1" lower on the driver's side at the leaf spring connection at the front bumper, versus the passenger side. Rear is not nearly as bad, but whole Jeep leans to the driver's side. Guy I bought it from had 4" sus. lift on it, and said "they all do that". Not really true, but I let it slide for the price I paid. Looks like it could be the leaf springs themselves, but not sure how to fix/debug. Any suggestions?
CALOcruiser is offline
post #2 of 8 Old 02-27-2010, 07:40 PM
CjAl
1980 CJ7
all the "cheap" ones do that. lol
check the frame for damage. if it's straight then get new spring...... good ones
CjAl is offline
post #3 of 8 Old 02-27-2010, 07:53 PM
Hybrid Jeep
1976 CJ5
It's called the CJ Lean... My 4.5" RE lifted CJ5 does not lean however!
To correct this.. you put a shim on .. let's see.. if it leans to Left.. then the shim goes on the right (pass side). This is of course if you are still spring under. But yeah.. personally I'd get a more quality lift kit. The cheaper kits WILL sag rather quickly actually.
Hybrid Jeep is offline
post #4 of 8 Old 02-27-2010, 08:00 PM Thread Starter
CALOcruiser
1978 CJ7
thanks guys. The frame is in good shape, gotta be the lift. I have heard of the "CJ lean", but didn't think I'd see it with an after-market lift. I suspected it was a cheap lift since the shocks are painted black, and no other markings to identify the make of the kit. Didn't realize it would lean that much due to cheap springs.
post #5 of 8 Old 02-27-2010, 08:07 PM
CjAl
1980 CJ7
was the PO like a 400 pounder? lol I'm a big guy... it happens
CjAl is offline
post #6 of 8 Old 02-27-2010, 08:18 PM
allornothin
mine leans alittle because my front frame on the drivers side is pushed down about a half inch from wheeling the heck out of it
allornothin is offline
post #7 of 8 Old 02-27-2010, 09:18 PM
CrazyHorse6
1979 CJ7
If you do some searches, you'll see a lot of info on the "CJ Lean". People say it comes from everything from bent frames from being tied down on railroad cars to a variety of other causes.
X2 on the shim. Mine pitched forward and to the drivers side, so I shimmed the passenger rear.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #8 of 8 Old 02-27-2010, 09:50 PM
alex211
1995 XJ Cherokee
My jeep leaned a little, but the passenger front frame rail is about an inch higher then the drivers side. I need to get that straightened before I box the frame, I'm sure the lean will go away then.
95 xj bone stock for now
alex211 is offline
TH400 driver's side leak NewdRiver_ Jeep CJ Forum 3 12-23-2009 10:42 AM
Different size front wheel cylinders on driver's side and passenger's side ariasbunch Jeep CJ Forum 3 07-13-2009 12:46 PM
Price for welding driver's side floor pan? Ken4444 Jeep CJ Forum 10 05-02-2008 09:03 AM
Driver's side blinker just stays on gtrpup2 Jeep CJ Forum 7 10-25-2006 01:43 PM
Off kilter on the driver's side DonQuixote Jeep CJ Forum 9 05-08-2006 08:25 AM
