CJ7 Larado: Larry, the Rebuild - Page 2 - JeepForum.com
post #16 of 56 Old 08-17-2013, 07:32 AM Thread Starter
VooDoo2
1978 CJ7
Tore down a Quadratrack transfer that was supposed to be stuffed but other than being empty (no oil) and one bearing being really dry i cant see any issues at all.
VooDoo2 is offline
post #17 of 56 Old 08-17-2013, 07:38 AM
skizriz
1978 CJ7
The big problems i have had with them so far is the chains being stretched, the clutch cones being torn up, or the splines on the inside of the cones being stripped out.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #18 of 56 Old 08-17-2013, 09:05 AM
kschitoskey
1983 CJ7
Welding up seat mount cracks
When I was redoing my CJ tub, I had extensive cracking as well. I'm over 250 lbs so I added 1/4" steel plates, approx. 6" X 4", to each of my seat mounts. I had spray in bedliner so it's not visible.
Great build. Shame you have to wait so long for parts...
kschitoskey is offline
post #19 of 56 Old 08-17-2013, 12:48 PM
lovett86
nice jeep
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #20 of 56 Old 08-31-2013, 06:52 AM Thread Starter
VooDoo2
1978 CJ7
f#*king panel shops. i work my ring out to get the car ready for paint, finally drop it around and in the past 3 weeks NOTHING has happened, its still sitting in the same spot i dropped it off. THEN i go there again today and he has gone on holidays for 2 weeks. When he gets back im driving it out of there and finding another shop.
Edit/Delete Message
VooDoo2 is offline
post #21 of 56 Old 09-24-2013, 08:13 PM Thread Starter
VooDoo2
1978 CJ7
Well instead of the panel shop doing anything i grabbed one of my own staff, walked into the panel shop and told him to get to work. 2 days later and the prep is done and we are ready for paint.
Inside the tub we used a product called URKI TEX. Its used as a stone guard on the sills of cars and is VERY cheap. $15 per L. 3 tins later and we have this.
We still need to shoot it with a black enamel over the top but its done the job. Should be able to do the outside in the booth toomorow. We got all the small imperfections filled and smoothed out, added a layer of sealer and spray putty to the car, rubbed back with 200grit then 400.
VooDoo2 is offline
post #22 of 56 Old 10-01-2013, 09:14 PM Thread Starter
VooDoo2
1978 CJ7
Inside done, today its getting the outside colour!!
VooDoo2 is offline
post #23 of 56 Old 10-02-2013, 01:27 AM
dan-cj7
Hi VD2,
Did you know that you have your front spring shackles on upside down. Did you have clearance issues with the spring hanger? Mine are close but after I put the engine on the frame they cleared.
Can't wait to see e finished paint.
CJ7 under construction - frame up restoration 4.6l stroker, AX15, YJ suspension
1984 CJ7 - Under construction
4.6L stroker with MPI & AX15 with D300
OME 2.5" YJ springs
http://www.jeepforum.com/forum/f8/dans-downunder-84-cj7-build-1299387/
dan-cj7 is offline
post #24 of 56 Old 10-02-2013, 04:00 AM Thread Starter
VooDoo2
1978 CJ7
The PO put on a massive steering box support making the shackles hit. The shackle hangles also made it impossible to install so i flipped em around for now. I still need to do some more front end work as i havent aligned anything or set caster angles.
VooDoo2 is offline
post #25 of 56 Old 10-08-2013, 07:16 AM Thread Starter
VooDoo2
1978 CJ7
Paint all but done.. We have to redo the dash panel as it seems to have been covered in silicon and managed to get full of fisheyes so i need to take it back to bare metal. Rest seems to have turned out ok.
VooDoo2 is offline
post #26 of 56 Old 10-12-2013, 06:04 AM Thread Starter
VooDoo2
1978 CJ7
Really starting to look like a jeep again
VooDoo2 is offline
post #27 of 56 Old 12-12-2013, 03:57 PM Thread Starter
VooDoo2
1978 CJ7
After 3 attempts to get the paint right on the dash its finally back and the last stage has begun. Doing some wiring tidyup, new speedo and clock, getting the HEI to work with the OEM tacho, new stereo and speakers
VooDoo2 is offline
post #28 of 56 Old 01-17-2014, 06:23 AM Thread Starter
VooDoo2
1978 CJ7
Dash wiring redone, all gauges now work, all lights work, heater works, rebuilt steering column with new bearings and indicator switches. Its a shame the previous owner hacked the speaker holes as finding a 4" square cover for the speakers has been a challenge. Not far to go now!
VooDoo2 is offline
post #29 of 56 Old 01-17-2014, 06:30 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hey, everything looks azz-backwards on your dash!!
Nice work, my friend. It's good to see your rig coming together.
Matt
Matt1981CJ7 is offline
post #30 of 56 Old 01-17-2014, 07:26 AM Thread Starter
VooDoo2
1978 CJ7
First time ive touched it since early Dec. Had a REALLY bad Xmas so it was nice to spend a few hrs today on Larry and get stuff done.
VooDoo2 is offline
