Cj7 junkyad hydroboost brake swap? - JeepForum.com
post #1 of 9 Old 03-30-2013, 10:49 AM Thread Starter
Alex77cj7
1977 CJ7
Hello,
I'm looking into upgrading my brakes. My current setup is factory manual brakes with drums all the way around. I was really looking into doing a junkyard hydroboost swap. I was looking at the astro swap but can't find any good write ups. Which swap is best and easiest? What all would I need to take with me when I leave the junkyard off of the donor vehicle? Does anyone know of a good write up on any of these?
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
post #2 of 9 Old 03-30-2013, 10:51 AM Thread Starter
Alex77cj7
1977 CJ7
Any bit of help is greatly appreciated.
Thanks,
Alex
post #3 of 9 Old 03-30-2013, 02:12 PM
hp_lovecraft
1981 CJ5
I was thinking about this topic a few days ago. Those aftermarket 3rd party vac boosters are so expensive, I thought this might be a cheaper option. But... in the end, seems like more work then its worth to me. Without power brakes I can still lock up my tires. Not sure I really need power brakes.
Anyway, these were the threads I remember looking at:
http://www.gmfullsize.com/forum/showthread.php?t=156800
http://67-72chevytrucks.com/vboard/s...d.php?t=523502
http://bangshift.com/blog/tech-how-t...-or-truck.html
hp_lovecraft is offline
post #4 of 9 Old 03-30-2013, 03:57 PM Thread Starter
Alex77cj7
1977 CJ7
Thank you so mich
post #5 of 9 Old 03-30-2013, 04:11 PM Thread Starter
Alex77cj7
1977 CJ7
Anyone know if I have to change my proportioning valve when i do the swap? or if i have to change any of the hard lines?
Thanks,
Alex
post #6 of 9 Old 03-31-2013, 11:13 AM
RDH
Subscribed....
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #7 of 9 Old 04-01-2013, 05:47 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
2Xtreme is offline
post #8 of 9 Old 04-01-2013, 09:22 AM
CSP
If you have discs in the rear a good donor is mid-80s Mercury Marquis. I pulled the hydroboost setup out of one of these years ago when I swapped to rear discs. Unfortunately it wanted the same real estate as my air filter housing, so it's on a shelf in my shop.
CSP is offline
post #9 of 9 Old 04-01-2013, 10:13 AM Thread Starter
Alex77cj7
1977 CJ7
I'm actually going to stick with drums for now. I have drums in the front so there's not much of a point of putting rear discs with front drums. I'm swapping to a ford 9" soon and idk what for a front axle. I've been reading up on doing this swap more and more lately and I think I'm just going to do swap to a dual diaphragm booster out of a Cherokee xj.. Seems like a lot easier of a swap and since I'm not going with any tires bigger than 35's 37's that booster should do just fine. Do any of you have a booster bracket either from a yj or cj that you could take pictures and measurements of and post for me?
Thanks,
Alex
