CJ7 ignition lock - JeepForum.com
post #1 of 2 Old 01-22-2002, 11:44 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Post CJ7 ignition lock
Does anyone know how to change the ignition lock on an 85 CJ7 with tilt wheel? Or do you know of a site that has step by step on how to? Or, maybe a fix for mine>>> it's not really bad, just that the key won't lock it. This is not good because it can be started without the key now. The key does look very worn. Maybe a copy of the key????
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 2 Old 01-22-2002, 12:09 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
I went to my local auto parts store and bought a replacement assembly - it takes the GM one and costs less than $20. There should be a magic hole in the column that lets you insert a small pointy object and with the key in the right position, remove the whole assembly. Since I couldn't get it to come out via the hole in the column, I removed my steering wheel to access the unit and once you figure out how to get the keeper to depress it is an easy job.
Steve
OldJeepguy is offline
81 cj7 ignition lock problems SouLo Jeep CJ Forum 6 02-05-2010 10:42 AM
Ignition lock cylinder help. Bubba Ray Jeep CJ Forum 15 10-20-2009 02:28 PM
Ignition Lock Cylinder Rocky_7734 Jeep CJ Forum 8 05-11-2009 09:59 AM
Ignition Switch? Lock? Rod? help please... breakthru Jeep CJ Forum 12 04-27-2008 09:58 AM
Ignition lock. djfuzzy Jeep CJ Forum 7 06-24-2004 03:36 PM
